Dremel 8220 information
super55Member since Nov 2012
Hello
I have a dremel 8220 but I want to know how I put this accessory in the dremel? the size is not the same.
thanks
Did it come with a wrench?
Can’t tell by the pic, but did you remove the collet nut? Remove the collet nut and feed the accessory shaft through it. Next, place the collet on the end of the accessory shaft. Once you’ve done that, insert the collet into the shaft of the dremel, tighten the collet nut, and your ready to go. Your instruction manual covers this. If you don’t have it you can find the manual online. If that isn’t it, there are different size accessory shafts that take different size collets. There are 4 that I know of 1/8″, 3/32″, 1/16″, and 1/32″. You may have an accessory that uses a different size than what you have. If that’s the case you’ll need a different collet. Lowe’s and Home Depot both carry them for under $5. Good luck
Joe MMember since Apr 2013
Agree with Conductor, you just need to switch out the collet nut.
While this is not the version you have, the steps are going to be basically the same and this is just a visual of what conductor posted.
http://www.youtube.com/watch?v=o6NCUnE-QIA
See around 1:45 is when he starts to change the collet
Sean
Hi guys,
I am so sad couldn’t get this model in Malaysia.
The only website i can get is http://www.dremelmalaysia.com/
Although most of the models is not available yet in Malaysia, but the website is so professional.
Check out yourself.
