My bits are dropping off 🙁
RichardMMember since Jul 2020
I am building a deck, and bought my first impact driver.  I went for a Dewalt DFC887 20V MAX-XR impact driver, and a Dewalt “Impact Ready” screwdriver bit set DWA2T40IR.  My theory was that the driver and bit set would have been designed to work with each other, and all would be plain sailing.  The manual for the DFC887 clearly states that, when installing an “accessory”, the “accessory is locked into place”.  However, I find that my stubby little bit (the only one in the set that fits my square-headed screws) does *not* lock into place, and falls out very readily.  This seems dumb beyond words to me, but then I’m not a tool-head and fully accept that I may be doing something wrong.
Is it me, or is this driver/ bit set combo actually incompatible?
Richard
It sounds to me like you are inserting the driver tip directly into the drill. You will need to use the silver 1/4” driver in the drill first. It has a notch at the end designed to lock into the impact. Then the tip goes into the driver and that should be held in with either a magnet or a wire ring inside the silver driver.
RickyMcGrath wrote:
Thank you for that.  You are, of course, totally correct  …  😀
This morning I used the driver/bit as you described, and it is much better.  The magnetic effect tends to hold the bit in place.  However, it is not totally satisfactory, as the bit still tends to escape from its magnetic clutches from time to time.  I think what I really need is an impact-ready square driver bit with a notch on its shaft, and use that directly in the driver.  Hopefully the hardware store has one.
Seems like the Dewalt bit set was a bit of a waste of money for me.
BTW, the DFC887 is just too strong most of the time.  It has 3 settings: ‘weak‘, ‘too powerful‘, and ‘even more powerful‘.  It is necessary to ride the trigger almost all the time, which is something the manual tells you not to do!  What it really needs is to have its ‘too powerful‘ setting toned down a notch or two.
ToolBaneMember since Jan 2018
Just don’t tell the lady
BiggieMember since Oct 2016
As a result of competition most impacts are too powerful.  Sure its great that a guy on youtube can drive a 1/2″ lag bolt or take off a lug nut but for driving screws they don’t need that much power.
