What particular limitations might I have with a 6 1/2″ circular saw versus a 7 1/4″ circular saw?
newusername84Member since Jun 2020
4x4s still require a flip and two cuts with either size saw.  The 6 1/2″ can cut 2x lumber no problem.  The depth of plywood and OSB is no problem with 6 1/2″.  I’m trying to think on what particular limitations I may run into if I pick up a 6 1/2″ cordless saw versus a 7 1/4″ cordless saw.
boonez40Member since Jun 2020
Just the depth and availability of blades. I believe you you can get more options and brands with the 7 1/4 and at a better price. Larger circumference should cut faster in theory.
I know I just switched back to a 7 1/4 saw so I will know in a few days how it does compared to my 6 1/2 saw.
Now the real question, can I run a 6 1/2 on a 7 1/4 saw. Hmmmmmm
Sent from my SM-N960U using Tapatalk
I just read the the 6 1/2 saw will not cut deep enough to make 45° cuts on 2×4’s
Hammer7896Member since Mar 2017
The Xsh03 will cut through 1 1/2” on a 45 bevel
Mike
Mike
Ok good to know
