Removing armature from DWS520 plunge saw
bozorMember since Apr 2020
I am trying to replace a damaged armature in a DWS520. I have stripped it down which was easy enough but I can’t seem to get the armature itself out.
[External image (preview.redd.it), not copied]
I have tried:
– wiggling it to see if it would loosen up – nope
– tapping on a small piece of wood that i rested on the drive shaft – nope
Annoyingly there doesn’t seem to be any videos on how to do this either.
Does anyone have any advice?
framerMember since Jan 2011
did you open up the gear case on the other end?
looks like a clip on other end of shaft. open the gear case.
I did open the gear case but there was nothing inside to unclip/remove.
bozor wrote:
you sure theres not a small snap ring at the base of that pinion shaft?
