New XR recip saw
The new range of DEWALT 20V MAX XR tools with POWERDETECT tool technology maximize performance when used with high-capacity XR batteries. Using the 20V MAX 8Ah battery, the DCS368 Reciprocating Saw will output up to 44% more power and get 60% more runtime than the standard XR Reciprocating Saw DCS367P1.
- POWER DETECT™ Tool Technology detects high-capacity batteries to maximize tool output
- 1-1/8-in stroke length delivers a fast cutting speed
- Keyless lever-action blade clamp for quick and easy blade changes
- Varible speed trigger with 0-3000 SPM provides blade control and fast cutting speeds
- Bright LED light for increased visibility in low light work areas
- 20V MAX; Maximum initial battery voltage (measured without a workload)
Great find. What is Power Detect?
Skickat från min moto g(7) via Tapatalk
Type “dewalt 8ah” into the Lowes search bar. A whole bunch of new combo deals pop up that I haven’t seen before, not to mention the 8ah batteries??
Mattias Blomqvist wrote:
7 hours ago, Mattias Blomqvist said:Great find. What is Power Detect?
basically a tool that has been optimized to use 21700 cell batteries.
there is also a new circular saw with power detect coming.
Jronman wrote:
On 2/16/2020 at 5:31 PM, Jronman said:basically a tool that has been optimized to use 21700 cell batteries.
Specifically, the tool knows whether the battery is using 21700 cells and adjusts performance to suit. So, the stated specs only apply if a battery with 21700 cells is used and the tool self limits with other batteries.
