Mr Sam
Sam425Member since Jan 2020
I have started to collect some t stack boxes and I have the DCK211D2T box that is for the 10.v drills! I don’t actually have the drills! But my mum accidentally bought me this instead of the screw tray box I was wondering is it possible to buy an insert to turn this into a screw tray instead of a drill holder box ?
You could simply keep all your screws and nails in the boxes they come in and load it up that way. But i think your going to need a dedicated organizer. I use boxes similar to this (tough system) to carry coils of nails.
paulengrMember since Sep 2018
No inserts unless you make them or buy two and move the bins from one to the other.
Personally I’m not a big fan of T-Stak. If you need one big bin Keter is cheaper for mostly indoor less demanding environments still with good seals like T-Staks. You get a lot more room in a Keter box. Lots of mechanics use them for their bolt bins. Great price comparatively. So this is good if you are on a job and just need say 4-10 bolts, nuts, and washers. One box can easily handle an assortment from 1/4-1/2” with various lengths.
If you need rugged then I would go with Toughsystem DS150s or Packouts. Both are “nail duty”. Instead of dividers each compartment is a removable bin. You don’t have the problem of nails getting under the dividers and you can pull out just the bins you need for a job. These are about the heaviest boxes out there. I kept them in the bed of a pickup for a couple years. All my parts and tools stayed dry, rust free, and was easy to grab just the stuff I needed for a job, and locked together for transport on highways. Perfect size for larger bolts, entire boxes of nails, etc.
Not sure what to do with T-Stak. Bins won’t hold an entire box of nails and you don’t get much space with the small size. The drill box is OK for drills but no option for say a Sawzall. For small electrical parts I like the Tough Organizers that are very cheap, stack like the others, and fit easily inside Toughsystem boxes like the dolly.
I think the whole concept of T-Stak is for say CATV techs. They need sort of midrange organizers that handle smaller tools and parts but very few larger bolts and nails I guess. They don’t need framer grade boxes or huge assortments of parts like electricians.
Personally I fall somewhere in between. I’m a motor service tech. So I might work on say a 1000 HP motor. The base bolts are say 1/2” and lugs are 4/0 with 3/8” bolted connections plus tape, termination kits. All obviously Tough System or Packout or Keter size bins. There are usually a bunch of small sensor wires, heaters with Stakons which fit best in Tough Organizers (lots of small parts). Same situation in the panel or drive. I could use T-Stak for some in between sizes but since none of these systems are cross compatible it does me no good.
