Hyper Tough 18V cordless drill
JDaughertyMember since Aug 2019
I have a Hyper Tough 18V cordless drill with a keyless chuck, built-in led light, and 21 adjustable torque settings that runs from 0-550rpm with no load speed. I was wondering what number(1-19) do i set my drill on for 24 to 28 ft. Lbs. of torque? Any type of info would be greatly apprechiated. Tia!!!
What make is hyper tough?
M80Member since Oct 2014
From the manual:
A little trial and error will show you what is the optimum setting for the situation.
I guess you can’t expect much from a $20 Walmart drill.
paulengrMember since Sep 2018
I don’t think any drill works that way except I think I’ve seen one with what amounts to a standard one with a torque sensor added to it. None of the major brands have torque control as a setting. Sure you can often adjust it but it’s not a set value.
igorsolMember since Nov 2019
You have to check in its manual. What is the full power of this drill and what this number stands for. Hope this will help to understand your drill.
