What ? 8ah 20v battery….
BremonMember since Dec 2014
Summer availability for USA and November launch for Canucks if memory serves. Piques my curiosity for a compact 4.0 as well.
Big AdamMember since Jan 2016
Certainly compact compared to the Flexvolt 6Ah/9Ah models.
framerMember since Jan 2011
wow. but i’d hate to see the price.
8ah….1/$179…2 pack $249…toolnut…June 30…same size as the 20v 6ah….
..so if they can make a 20v 6ah and 8ah the same size then a 10ah should be the same size too?……..or….a big flex/20v..9ah and 12ah the same size ,shouldn’t a 15ah be the same size?
A flex 15ah would be 5ah 20v ? And that would let us frame houses with just 2 of those per tool all day…. We use the 12ah now..
Are these the same cells as the 6ah?  I’m interested in replacing some of my aging fleet of 4 and 5ah, and looking at the scale of economy I’d be getting a lot more Ah by buying the 6’s at two for the price of one 8ah.
Starting to look a bit like the 12ah…just isn’t worth the cost in scale.
CoreyMember since Mar 2019
I’m curious how it’s the same size as the 6. Got to be new cells, because there’s no way you’re adding 21700s in the same form factor. I’m surprised this has gone under the radar, given the battery wars as of late. Ditching 18650s was broadcast by almost every brand. I still find the sweet spot on 20v to be the 5s, personally. I’ll throw a 6 on the 3 speed, or the 1/2″ impact, but they are considerably larger than the 4/5s. I actually down graded the deep cut band saw to the new slim 3ah though, helps on weight and seems to do just fine.
Sent from my SM-G930V using Tapatalk
Current 6.0Ah XR is 21700 cells
New 8.0Ah XR is higher amp rated 21700 cell. Same size as 6.0Ah XR
Sent from my SM-G973U using Tapatalk
