Does anyone know if the “thrust bearing,” the dime-size circular ball bearing ring in the pivot recess, is supposed to be lubricated? I can see factory lube on the O-ring that surrounds this area, but I can’t tell if the ball bearing ring should be greased or not. Mine was all choked with sawdust, so I blew it out with compressed air and would like to know before I put it all back together whether or not the factory wants that to be lubed. Thanks.
Welcome to the forum.
From the DWS780 Instruction Manual, page 14: “All bearings are sealed. They are lubricated for life and need no further maintenance.”
Here is the manual:
Hello all.
Im a dewalt dws780 user and suprise suprise yhe shadow line led has stopped working.
Any reccomendations on a cheaper fix to the genuine expensive parts?
Apologies if this has already been discussed.
regards
Gareth, Wales, UK
That’s crazy it stopped working. Usually they are very reliable. I would have to think there is an after market parts but haven’t dealt with it before.
Dewalt 780 miter saw is very good and comfortable for our work. you can buy a miter saw and work easily. if you want to buy a good miter saw then you can go to amazon. there you will find your chose the full product.
thanks
