DeWALT DCF887M2 20V MAX XR 3-Speed Impact Driver Kit
The DCF887M2 Type 3 20V MAX XR 3-speed impact driver kit was added to my tool kit.
An impact driver is not a tool that I have owned / used previously. I am really loving how this drives fasteners in difficult applications. I am very happy that the fastener is driven with little or no head damage. This is also very handy for removing difficult fasteners, also with little or no head damage.
This DCF887M2 kit includes: the DCF887 impact driver; two DCB204 4.0Ah 20V XR Li-Ion batteries; a DCB115 4.0A 12V/20V MAX battery charger; a N268241 belt hook and a clam shell tool box.
The DCF887 has great control features. One is the three-position mode switch. Mode 1 is identified as 0-1,000 rpm 20 ft-lbs Precision Drive. Mode 2 is 0-2,800 rpm 125 ft-lbs Normal Impacting. Mode 3 is 0-3,250 152 ft-lbs High-Speed Impacting. The Mode 1 permits precise driving control in many applications, until the tool runs out of torque. Mode 2 gets the job done to drive or remove the fastener. My limited usage has not needed Mode 3 yet.
The tool has a variable speed squeeze trigger switch, with continuous partial speed operation not recommended. There is also a forward / locked off / reverse switch.
The tool has three forward-facing bright white LED lights, to illuminate the work area.
The kit includes a N268241 belt clip. I also added a N268199 bit holder on the other side of the tool.
The kit includes a nice plastic clam shell tool box, with storage locations for the extra battery and for the battery charger. The hard plastic tool box measures 16″ x 9½” x 4¼” with a pair of metal lever draw-down latches, a full-width piano hinge and a metal hinge pin. My application has better utility without the extra battery and without the battery charger, instead using that interior volume for related tool storage. I found that the Bosch MP500T carbide drill set and the Milwaukee 48-89-4631 23 titanium drill bit set fit nicely in the case with those kit items not present.
Bosch MP500T 5-Piece Daredevil Rotary / Impact / Hammer Drill Bit Set –
/forum/topic/14363-wingless-accessories/
Milwaukee 48-89-4631 23-Piece Titanium Shockwave Drill Bit Set
20V MAX XR Belt Hook and Tool Holder –
/forum/topic/14432-wingless-20v-max-xr-belt-hook-and-tool-holder/
[External image (farm5.staticflickr.com), not copied]
[External image (farm8.staticflickr.com), not copied]
I see you put a set of Hammerdrill masonry bits in the box. I understand they have a 1/4 in hex to lock into the tool but they are better used in a hammer drill not an impact
JakeDewalt wrote:
12 minutes ago, JakeDewalt said:I see you put a set of Hammerdrill masonry bits in the box. I understand they have a 1/4 in hex to lock into the tool but they are better used in a hammer drill not an impact
Thanks, that is correct.
My tool set does not yet include a hammer drill, so I am currently drilling masonry either with my rotary drill or my impact drill.
This Bosch ¼” hex drive shank with the power groove retention radius set is rated for rotary, impact and hammer.
is It truly necessary for us to know every time homes wipes his nose or buys a new tool?
Please do everyone else a favor and condense all this stuff into a single thread. This is the Dewalt forum not the wingless forum
Actually disregard @Babysaw comments.
This is is a forum for members to post.
For members that may feel they need to guide, direct or otherwise offer non constructive criticism or jabs I would highly suggest you write your comments on a piece of toilet paper and blow your nose into said notes. Do not use the forum to spread disrespect to other members.
Thanks, Chris.
Lol dude if this was a subreddit he’d have been flagged for spamming days ago. I don’t think it’s unreasonable to ask for all this stuff on a single thread so as not to clutter every other user’s experience?
Babysaw wrote:
3 hours ago, Babysaw said:Lol dude if this was a subreddit he’d have been flagged for spamming days ago. I don’t think it’s unreasonable to ask for all this stuff on a single thread so as not to clutter every other user’s experience?
Read your pm.
Real simple “dude” just don’t read his threads if you don’t like it instead of “doubling down”
I for one enjoy reading and seeing his pictures showing the same.
Sent from my SAMSUNG-SM-T377A using Tapatalk
Knock it off.
It has been taken care of. Thanks, Chris
I actually brought my DCF887 into work today to let a coworker use it, only to find out she no longer needs it. I lucked out and got mine in a kit with two 2Ah batteries for $90 after it was returned.
Impact drivers are great, aren’t they! My first was part of my first Li-Ion kit, an 18v Porter Cable. That and the 12v PC impact were given away along with the rest of those platform. I also gave away a Hitachi I had. Currently, I have the Ridgid, DCD886 and 887, and two M18 Fuel One Key impact drivers. The DeWalt remain the most used.
Bosch designed a set of masonry bits for impact use, they perform okay on smaller stuff but heavier duty tasks forget about it, carbide is too soft on it the tips wear pretty quickly
@wingless this is a great impact from DEWALT except one thing, I hate the speed selector, wish they would have made it electronic like pretty much any other brand
wingless wrote:
On 1/3/2019 at 11:11 AM, wingless said:The DCF887 has great control features. One is the three-position mode switch. Mode 1 is identified as 0-1,000 rpm 20 ft-lbs Precision Drive. Mode 2 is 0-2,800 rpm 125 ft-lbs Normal Impacting. Mode 3 is 0-3,250 152 ft-lbs High-Speed Impacting. The Mode 1 permits precise driving control in many applications, until the tool runs out of torque. Mode 2 gets the job done to drive or remove the fastener. My limited usage has not needed Mode 3 yet.
11 minutes ago, JimboS1ice said:@wingless this is a great impact from DEWALT except one thing, I hate the speed selector, wish they would have made it electronic like pretty much any other brand
The tool has both a variable speed trigger switch, plus the three-position mode switch.
wingless wrote:
2 hours ago, wingless said:The tool has both a variable speed trigger switch, plus the three-position mode switch.
Sorry i don’t think I was clear, the 887 has the speed selector on the bottom of the tool but its a manual switch, i find a little tedious to use, tend to skip speed to an go back and forth between 1 and 3, same war i fight with the DCD 996… any who most other manufactures on multi mode/speed impacts have an electronic button that switches the speeds like Milwaukee, Hitachi, Bosch, Makita…
On 1/8/2019 at 5:35 PM, JimboS1ice said:Sorry i don’t think I was clear, the 887 has the speed selector on the bottom of the tool but its a manual switch, i find a little tedious to use, tend to skip speed to an go back and forth between 1 and 3, same war i fight with the DCD 996… any who most other manufactures on multi mode/speed impacts have an electronic button that switches the speeds like Milwaukee, Hitachi, Bosch, Makita…
Personally, I far prefer to have a manual analogue switch than an electronic button that is far less durable. I’ve had several various brands that have had that electronic switch fail.
