XPH10
Carib InnMember since Dec 2018
Hello – first post. I  have a new XPH10 cordless hammer drill that suddenly will no longer run but the light does come. Switch tests OK. Battery  fine. I am not getting any voltage to the brushes. There is a small rectangular piece about 1/8 thick attached to a heat sink which sits under the motor. 3 black wires go to it. There is continuity through all wires so none are burnt. I have a feeling that is what is wrong but can not find that part in any schematic. What is it? Any other ideas?  Can’t send it back. I live in the Caribbean and it will cost more than the drill is
worth.Thank you   Bruce
Can you send pictures ? And did this just happen all of a sudden or when you went to use it ?
SchenzhenSpecialMember since Oct 2017
Motor controller transistor. The one currently installed in the drill should have a product code which you can search to find a replacement. They’re quite cheap to replace.
If you have continuity at all three points it most likely is faulty.
It doesn’t have its own item code on the spares catalogue, however.
