DW705 (Version 8) Miter Saw Won’t Brake
JRoppMember since Nov 2018
Hoping one of you guys can help because I’m running out of ideas!
So far, I’ve:
  1. replaced the brushes (didn’t help)
  2. cleaned the commutator (didn’t help but looks brand new now)
  3. replaced the switch (even though my multi-meter is telling me the old one is working properly)
What else could be the problem?  Saw takes about 8-10 seconds to come to a rest.
Thank you very much for any ideas!
Jeff
google search says it is the armature if the other fixes you did did not fix it
methodMember since Aug 2018
You can test the armature with a multimeter for damage to any windings.
JRS5565Member since May 2014
check the blade tightness
