Awsome video. Thanks for all your hard work.
Thanks Guys, great video!
Nice job guys 🙂
Thanks friends!
@dwain Dwain if you’d had to take a guess and you would do these tests on the flexvolt grinder. What You’d think the results would be ? ( Like guessing hypothetically 😛 )
id assume you’d score the power more like 25 ? ( Compared to 20 for the 18v deWalt grinder for example ).
how would the runtime go ? Logically I’d think the flexvolt grinder would have less runtime then their 18v grinder you tested right ? 🙂
I’m surprised one unit tied for top marks even though it’s been around since 2014. That’s ancient the way tools are progressing right now.
kornomaniac wrote:
On 9/10/2018 at 8:50 PM, kornomaniac said:@dwain Dwain if you’d had to take a guess and you would do these tests on the flexvolt grinder. What You’d think the results would be ? ( Like guessing hypothetically 😛 )
Hi korno.
If it’s pure guesswork, I reckon the flexvolt would probably be around 27-30 for power by comparison.
No idea on runtime. It may win because the test would be far easier for it and hence not heat up the cells too much….
dwain wrote:
22 minutes ago, dwain said:
Hi korno.
Aha! 🙂 That alot of power difference.
Unless their was a thermal shutdown on a battery do we think that a hotter running battery looses runtime ?
kornomaniac wrote:
1 hour ago, kornomaniac said:Aha! 🙂 That alot of power difference.
Yep. As I understand it, heat causes cells to lose efficiency quite markedly. Seems that cold also affects performance – https://batteryuniversity.com/learn/article/discharging_at_high_and_low_temperatures
This is why you will never get half the runtime of a 4ah battery on a grinder using a 2Ah battery.
EDIT: hmm perhaps I’m wrong and increased temp only hurts the lifecycle of the cell, not it’s immediate performance …
EDIT 2: It seems that batteries can have increase ‘performance’ (meaning amperes out) in high temp, but it also significantly increases the self-discharge rate.
Seems like youll have to redo your testing with the flexvolt grinder 😀
and while you’re at it…. The deWalt and Bosch grinders with normal 6 amp batteries 😛 hahahha 😀
might as well use a Procore 12 ah and a Flex 12 ah and an m18 HO 12 ah.
I’ll let you guys handle those minor extras 😉
I always enjoy your videos, Dwain. Keep them coming!
