Tool Clip NUTS! Size ?
tombukt2Member since Jul 2018
looking to find the hex nut size of tool clip screw nut mounts in tool in a yellow hex hole behind the tool clip hole on all 20V tools right under 5 slots ? dewalt cannot even tell me  upload a pic in a few min need to applt this clip to dcs 355 multi tool no threads in hole for clip screw……
BiggieMember since Oct 2016
I’m not real familiar with sizes of machine screws but I know in the past when I’ve needed a belt clip screw I just took one out of a tool and went down to my small town hardware store and they match one for me.  I’m sure if you have the screw they have a hex nut for it because it seemed to be a pretty common size screw.
not so far  most hardware stop at 4-40 im going round to all tools and pull the side im not using .DOH. DCS 355 hath no threads in clip hole ..
im sure theyre other tools missing nuts too. looks like they only install in certain models .. but the yellow hex is theyre on all.. Photo from the original forum
Just pop one out of another tool you have from the side you are not using. That is what I did for my multitool.
jkeating3Member since Dec 2014
I am pretty sure they are m3.
D WMember since Jun 2016
The.Handyman wrote:
Great idea. I’ll do this.
Are they hard to remove?
Mattias BlomqvistMember since Apr 2015
That’s what I did too. As far as I can remember it wasn’t that hard, but the clip needed some small bends and kinks to fit the multitool if I remember correctly or else the battery would not slide into place.
Skickat från min LG-H815 via Tapatalk
Not hard at all. Thread the screw in and then soft tap it with a mallet to pop the nut out on the battery side. It’s a friction fit in the plastic hex.
Put the nut in the OMT and use a newer style belt clip, just not a real old one, and all is well.
yep done that now ive used up all those just bought some new tools  ordered some m3 nyloks we’ll see
