Help. Can I get a use this without a bag? I am a DIY’er and woodworker. Thank you in advance for your help
Bags are cheaper than filters so, while you probably CAN use one without the bag, you’ll clog up your filter that much faster, which will cost you more in the long run. If you’re worried about the cost of bags adding up, you can always build yourself a cyclonic extractor to attach to your DC. I love my dust deputy and haven’t had to change out my DC bag once since I’ve bought it.
Is this the model that you are talking about. If so you can use it without the bags. But 35 bucks for 5 bags is a lot cheaper then to replace the Hepa and main filter at 150 bucks. The Hepa filter is so fine it will plug up fast. If you are going to spend 600 bucks protect your investment buy the bags.
Never saw that Milwaukee vac, it looks nice
Nilfisk Alto model. Same as makita
here is a way to make single use bags reusable. [External image (i36.servimg.com), not copied]
Interesting hack. Does any of the dust escape out the bottom of the bag past the clips?
Those aren’t my pictures but I’ve done this hack. I use it mostly for saw dust and as long as you wrap the dowel a couple time and clamp it, I dont have any escaping dust. If anything did escape it would be pretty minimal and I would say just add another clip.
