Ryobi just announced they are coming out with some new tools:
Ryobi Project Light – P790 and will retail for about $50
SPECIFICATIONS:
• Lumen Output: High (lumen output 900), Medium (lumen output 600), Low (lumen output 100)
• Runtime: 35 Hours on Low Mode using a RYOBI ONE+ High Capacity Lithium+ Battery
• Weight: 1.1 lbs.
• Power Source: AC extension cord or any 18V ONE+ Battery
SPECIFICATIONS:
Ryobi Drywall Screwgun – P225 and will retail for about $100
SPECIFICATIONS:
• Brushless motor provides longer runtime, more power, and longer motor life
• Adjustable and removable nose cone for increased accuracy
• Variable speed trigger with lock-on feature: 0-4,700 RPM
• QUIETDRIVE Technology eliminates noise in-between driving applications while prolonging battery charge during use
• Drives up to 3,000 screws per charge
• Heavy-duty clutch engages when bit is pressed to the fastener
• New and improved MAGTRAY™ magnetic holder for convenient placement of screws and bits
• New, innovative, fastener-free belt clip easily mounts to either side of the tool for convenience
• LED Light illuminates the work area and remains on after trigger is released
• GRIPZONE™ overmold with improved micro-texture for optimum grip and user comfort
SPECIFICATIONS:
Ryobi Floating Speaker – P3520 and will retail for about $80
SPECIFICATIONS:
• Optimal LED output that changes with the sound of your music
• 360° Bluetooth® speaker for enhanced sound projection
• IPX8 waterproof
• Onboard volume & light show control
• 8hr runtime on P108 4Ah battery, 4hr runtime on 2Ah battery
• Flip resistant design for an enhanced listening experience
• Customize your lighting experience with 3 operating modes: Play Mode, Pulse Mode, Sleep Mode.
SPECIFICATIONS:
Ryobi Light – P790 and will retail for about $80
SPECIFICATIONS:
• Over 1200 lumens of light output
• Multi-point adjustable light head for various applications
• Over 24 Hours of runtime using a ONE+ High Capacity Lithium Ion Battery
• High (lumen output 1200), Medium (lumen output 700), Low (lumen output 100)
• Compatible with all 1/4″ x 20 tripod mounts
• 360º light head rotation for variety of positions
• Multiple hanging options
• Part of the RYOBI Lineup of Over 100 ONE+ Tools
• Includes P795 18V Hybrid LED Color Range Work Light, Tripod Adaptor and Operator’s Manual
SPECIFICATIONS:
Ryobi Underwater Vac – P3500K and will retail for about $180
SPECIFICATIONS:
• Battery: 18V
• Runtime: Over 50 Minutes
• Weight: 7 lbs.
• Canister Capacity: 3 Liters
SPECIFICATIONS:
Ryobi Sweeper – P3260 and will retail for about $140
SPECIFICATIONS:
• Powerful dual brushes sweep up large and small debris, including nails and screws, wood scraps and garbage
• Over 2 hours of runtime using a RYOBI P108 High Capacity battery
• Rotating brushes effectively clean along walls and edges
• Conveniently located foot-actuated power switch
• Rear Wheel height adjustment for use on various terrain levels
• Transparent tub shows how much debris has been swept
• Integrated LED headlights provide improved visibility for a number of applications
• Adjustable, pivoting handle and rubber feet provide optimal ergonomic and compact storage
• Wide 21 in. cleaning swath quickly cleans a wide area
SPECIFICATIONS:
Nice! Ryobi is certainly keeping super active. The transfer pump is on my list for must haves this spring.
I’m still looking out for that radio controlled truck
100 dollar drywall gun that’s a deal!!!
I like that Ryobi doesn’t seem to care about making niche tools. They have made some crazy sh!t and offer stuff I wish Makita would make.
I saw these a few days ago, and I’m pretty sure I fell in love with the idea of a pool vac that runs on Ryobi batteries. My mind instantly started trying to find excuses to give the wife as to why we need the new Ryobi pool vac…
HiltiWpg wrote:
45 minutes ago, HiltiWpg said:I like that Ryobi doesn’t seem to care about making niche tools. They have made some crazy sh!t and offer stuff I wish Makita would make.
Seriously some brands added cordless compressors finally, but wtf the only cordless inflator was from Ryobi!! Also 18v powered ope is a great option for some people Ryobi is a great 3rd platform to own just because of the crazy.
