Makita Drill No Reverse
Bloch98Member since Mar 2015
Hey guys I’m hoping someone can help me out here. I have a Makita 18v drill XFD01 that will not work in reverse. The drill works in forward without any issues and when it is switched to reverse only the light lights up. I tried blowing out the switch and brushing all the dust and dirt out but still no luck.
HiltiWpgMember since Sep 2015
Switch most likely.
Yeah, it’s probably the switch or wiring the switch. More than likely the switch, carbon and general grime builds up on the contacts and it stops working. I imagine its a cheap fix with a little soldering.
