DeWalt D55146 Air Compressor Diagnosis help…
RoyMember since Jan 2018
My DeWalt D55146 air compressor has quit “compressing”….
It’s about 11 or 12 years old and has been a good one, but last weekend I went our to the shop and heard it running.
I knew when I first heard it that something was wrong(abnormal). It just did not sound right.  Even though it was running (really fast),
the gauges showed “zero”…  I’ve never worked on compressors and not sure where to start.
I have attached a URL to my YouTube Channel with a short (13 sec) video, hoping someone can watch and listen to and
maybe help diagnose the problem.  Notice that when I shut if off, it continues to cycle, like no compression.
Thanks to all for help, idea’s & suggestions.
JpgwoodworkingMember since Jan 2018
Only so many things it can be. Blown head gasket or broken piston ring would be my guess. In the time it would take to run a diagnostic test you could just pull it apart and look.
Find the Leak
LOL, “find the leak” ;-)…
Yea, I’m going to pull it apart this weekend and see what I can find. I’ve done a lot of “maintenance”, but never a compressor. I just thought I’d throw this out there thinking maybe someone may have had this same issue and a quick fix.  The drive belt is definitely in need of replacing and a good general cleaning can’t hurt ether.
I’ll report back my findings.
Drain Valve Closed and Functioning ?
Yes. the drain valve checked good.
Only had time to remove the piston this afternoon and it & the ring/seal seemed fine.
Will keep investigating.
Isn’t that a loud compressor? 12 yrs old….I’d get the 200psi trim compressor with a holding tank…quiet as can be…
