M12. Band saw
Anybody got one ? Thinking about getting it for cutting threaded rod we use….Dewalt has one but the bottom is closed in on the m12….looks nice
I have one, I basically only use it for threaded rod. It’s nice and compact, cuts rod really easily and cleanly.
Great video ,thanks…ya that’s all I need it for. Tough cutting rod with a sawzall or hacksaw or metal saw…
The DeWalt dcs350 is an option, albeit more expensive and only good for threaded rod, if you have to do a ton of it.
[External image (images.homedepot-static.com), not copied]
@Stercorarius..thanks , appreciate it,,we cut 5/8 to an 1 1/4” threaded rod and I think that cutter stops at 5/8” . ..I think….and the band saw  will probably come in handy doing something else….I thought about a metal saw but I don’t know how clean the cut is …..
BiggieMember since Oct 2016
Framer joe wrote:
Metal circular saws will cut every bit as clean as a band saw and much faster.  They do have a bit of a learning curve as far as accuracy on something that small but no more than a regular circular saw you’re familiar with.
Framer joe wrote:
Yeah probably best to go with the band saw then. I have a portable Metabo bandsaw that’s a mid size that was a dream for stuff like that when I still had the batteries for it. It was brushed as well so the m12 will probably be perfect.
I have the M12 bandsaw and love it,  great tool
mlindholmMember since Jan 2018
I picked up the M12 bandsaw nearly 4 years ago now, for around the home project purposes.  It took me a while to get around to using it much, but I love it every time I use it.  I’ve used it for cutting down 3/8″ bolts, EMT conduit, 14ga 1″ steel tube for projects, aluminum angle…anything that’ll fit in it.  I even cut a 1″ square cold rolled steel bar for one project.  It took a while, but eventually made it through.  I just wish it was a little bigger, because you can’t quite fit 1.5″ ID aluminum tube inside.  It was sized to fit unistrut though, so like trying to haul drywall in a Civic, I can’t really complain when it wasn’t designed for that job.
Bmill25Member since Jul 2015
How well would it cut rebar?
HiltiWpgMember since Sep 2015
It does, but it eats blades. [emoji15]
