bookum
bookumMember since Nov 2017
Hi…
I bought a 9207spc that did not come with the rubber backing pad- they do not seem to be easy to come by or to determine which accessories are compatible but I’m hoping the model(s) that replaced the 9207 would work. In addition, I need to find a resin-backed 36 grit grinding disc (for fiberglass) and a power pad that will work with this tool. I’m also not sure how (or if) the grinding disc works with the rubber backing pad- does it attach (hook and loop?) to the pad or does it attach independently to the tool?
Any insight on this would be most appreciated!
