So I got out the user manual for the wall rack and was looking through it so I would kinda get an idea of how to instal it into my garage. Seemed fairly straight forward. Assemble the rack then screw to studs then screw to floor. I checked for installation videos and could not find any but I always looked at how the bottom was tied to the floor. The rack was tied to a 2x then the 2x to the concrete floor. It mentions nothing about how to instal on a concrete floor in the directions. I would think that concrete would be the most common material to fasten the bottom to. So now to my question. Can I skip the 2x method and tie the wall rack directly to the concrete? I haven’t even looked at what screws are provided. They might just be wood screws. If I have to do the 2x method what screws would you guys recommend to tie the 2x to the concrete? Would I need to use treated 2x for a garage floor? Do you guys got any other suggestions for rack instal?
No help here as I have some to install myself……. just disappointed [emoji17] that Dewalt cheapen the brackets
I don’t mind as much because it isn’t being stressed as much as if it was more mobile like the tough cart.
As the posts are resting on the concrete, there should be no issue with using tap-cons or drive pin anchors to fasten them to the concrete. The only thing you are trying to limit at that point is lateral movement. The wall mount brackets will have the most stress on them.
Like JMG said Tapcons to Install the 2x to your Slab. Yes Preferably PT on any Cement.
I prefer titen bolts, we bolt the house down with them…they come in all sizes..good luck with the rack system 🙂
Thanks for the help. I take it the 2x option is the best option.
Is there a Warrantee on the Racks
I would thing Limited Lifetime
Great set up @snohiker..you are set up sweet in there. Love the full size tool chest in there. ….I have that Dewalt trim compressor 200psi,,quiet as a dryer…works awesome…and a fridge ? Gotta love it…great job man
Tapcons are fine. Re:breaking a bracket…pretty sure I read that these were not intended for trailer setups, so having decent weight in them and then hitting a pothole could be problematic.
does the van rack use stronger brackets?
Jronman wrote:
On 12/3/2017 at 2:41 PM, Jronman said:does the van rack use stronger brackets?
I know the van rack comes with folding arms to save space when not in use, unlike the wall rack. And I think the uprights might be made from a single rail instead of 3 pieces joined together (but the images are a bit unclear).
My problem is securing the boxes to the wall rack. The ToughSystem Trolley has a locking mechanism, but I can’t see an easy way of adapting this to the wall or van racks. Has anyone else managed to do this?
@Toolman Tim maybe the side handles are enough?
Jronman wrote:
21 hours ago, Jronman said:@Toolman Tim maybe the side handles are enough?
I’m really looking for theft prevention on a wall rack in the workshop, rather than holding the boxes in place whilst driving the van.
Toolman Tim wrote:
3 hours ago, Toolman Tim said:I’m really looking for theft prevention on a wall rack in the workshop, rather than holding the boxes in place whilst driving the van.
I would a security system work better? The way I see it is a guy could easily cut the plastic and have access to whats inside the boxes. You could maybe have some kind of locking bar that you put in front of the rack to keep a guy from pulling out the boxes?
Jronman wrote:
18 hours ago, Jronman said:I would a security system work better? The way I see it is a guy could easily cut the plastic and have access to whats inside the boxes. You could maybe have some kind of locking bar that you put in front of the rack to keep a guy from pulling out the boxes?
Thanks for the suggestion. I noticed the tough-system handcart has a concealed locking system that engages with a metal latch on the rear of each toolbox. This makes it impossible to release the boxes from the handcart without a padlock key. Unfortunately this system is built into the cart and not available with either the van or wall racks. I might try to secure a 1cm diameter steel rod vertically behind the wall rack and inside the rear metal latch on each toolbox.
Has anyone bought a wall rack recently? Are people still breaking these brackets?
Sarbatche wrote:
17 hours ago, Sarbatche said:Has anyone bought a wall rack recently? Are people still breaking these brackets?
I have instaled 3 since I made this thread. I havent broken any brackets but I wouldn’t say I am rough on them either. The one rack I take off a couple boxes to take to work then I put them back on at the end of the day.
