I take it my rail is out of square?
I have gotten into the habit of squaring up full sheets of plywood with the track saw.
so I spent quite awhile trying to square up a piece of plywood with my track saw to get it ready to break down and it has been difficult to square for whatever reason. I didn’t have issues on any other pieces that I can remember. Now I’m worried that the pieces I cut from other pieces of plywood are off too. I check with my combo square on the new piece which I have calibrated for square many times on an edge cut by a Festool track. I also measure if parallel sides are equal in length. It seems like if I want the side square it will throw off the measurements for the parallel sides but if I want equal sides it throws off my square which doesn’t make sense. I’m not real experienced yet with squaring things up but I think I may have found out part of the issue. As you can see in the picture my square shows the rail to not be square. I would expect the track to be square. I checked my festool track and it is square.
HiltiWpgMember since Sep 2015
You have stumbled onto “Big Lumber’s” secret plan to slowly tilt the world by 10 degrees…
Wouldn’t it only matter if the track is straight? Measuring your diagonals is a better way to check for square. Checking for parallel only tells you if the sides are parallel.
Sounds like the wood you have now is a slight parallelogram.
