I have had this laser level for a while now. I haven’t used in a bit though. Brought it out this week as I was starting a deck build. Everything powers up and lights up but the head doesn’t spin. Any similar experiences, suggestions, or solutions? If not a trip to the service center I guess. Might not even be worth fixing?
is there a button to turn the spin on??
framer wrote:
11 hours ago, framer said:is there a button to turn the spin on??
No. It’s pretty basic – press the button, wait for it to self calibrate, and then it should start spinning. That’s what it used to do.
I’m sure it’s something internal. I’ll see what the service repair says.
Last week I had the unit screwed to the ledger board and I had to manually aim the laser dot towards the footings so I could get the post height. I only had 3 posts but I was by myself and it was annoying going back and forth to get this laser dot to hit the grade rod.
My colleague who is a home builder is going to lend me his for my next deck build in two weeks.
I’m not going to buy another one because I don’t use it much at all. I only do one or two decks a year – I’m more into bathrooms and kitchens.
With that said if the repair
cost is too much I’ll just bin this POS.
I’d take it apart myself. That shouldn’t be all that complicated.
Do you hear anything spinning in there? It could be a belt or a nylon gear slipped out of place.
4 hours ago, BMack37 said:I’d take it apart myself. That shouldn’t be all that complicated.
Maybe I will. Warranty has long since elapsed.
Looking for used DW074KD for parts
