Compressor Advise
Ok here is the deal.
Expanding my Siding company and adding a 2nd Installer.
We used Red pancakes and hate them.
We both use Hitachi AVH2 Siding nailers.
I need an air compressor that can run 2 Siding installers (Sheathing as well with 8 OC in field and 4OC on egde). Rapid fire does happen and the compressor needs to be able to handle both nailers firing simultaneously at any pace then work requires.
I need the compressor to maintain the proper PSI to both guns under constant load.
Is the Hitachi Wheelbarrow my answer or can I still remain Electric and be fully satisfied.
Thanks in advance for any help.
JMGMember since Dec 2015
Regardless of the compressor you end up choosing in the end, it will probably be a good ideal to add a regulator for each gun supply line. Hose length and size can also cause issues for gun performance. If your compressor ends up over a hundred feet away from where you are working, a booster tank on the end of a half inch id hose with a regulator manifold mounted on it to supply your guns can cure pressure drop issues caused by longer small id hose lengths. Think of it as a step down transformer… Unregulated high pressure to the secondary tank and a functional pressure level on a short air lines to balance pressure variations.
calidecksMember since Sep 2017
Your best bet will be a twin tank wheel barrow like you mentioned. With that kind of use, even if a smaller one could keep up, that too much work to constantly ask from the small compressors. Imo.
Mike.
_______________
[emoji631] [emojiyeq]
