new cordless “flathead” grinder DCG405NF (Europe model number)
Hi
just spotted on web the picture
DCG405NF / flathead cordless grinder (Model Number in Europe, N = bare tool)
brushless
The DeWalt DCG405NF is the sister model of the DCG405N, with a “Flat head” design for access to acute angles.
It has the latest DeWalt Brushless motor and an excellent cutting depth.
  • Flat head for access to acute angles and has an excellent cutting depth
  • Ergonomic slim body with rubber over-mould for improved comfort and control
  • Compact gear case for increased access to tight spaces and gives excellent cutting depth
  • Slide switch provides less user fatigue. Built in no-volt release gives protection against accidental start ups when new battery is installed
  • Constant Clutch and E-Clutch protects from kickbacks, cuts and wheel bursts
  • Braking time of < 2 seconds when the trigger is released to help reduce accidental contact and injury
  • 1 or 2 touch guard for quick and easy keyless adjustment
  • Battery Chemistry: XR Li-Ion
  • No Load Speed: 9000 rpm
  • Max. Disc Diameter: 125 mm
  • Spindle Thread: M14 (22 mm)
  • Weight: 2.5 kg
Saw the image last week but it’s so small and low resolution it wasn’t worth posting.
Good stuff though. More options.
I wonder how you guys find this stuff?
