MAKITA LXPH03 New Brushes wont’t start
engiabMember since Jun 2017
Hi Guys.
I have a Makita xph01 and a Lxph03. I replaced the carbon brushes for xph01 and works good but I replaced the carbon brushes on Lxph03 and when I pressed the trigger it try to start and makes a spark and won’t start again. Do you know what happen and what I must do to fix it. I will appreciate the help.
Burnt up the motor ?
hi kornomaniac, there any test for the motor, to know if it is working or not?
HiltiWpgMember since Sep 2015
You can quickly meter it for a short in the windings.
Sent from my Pixel using Tapatalk
engiab wrote:
20 hours ago, engiab said:
Hi Guys.
Possible Burnt up armature it is common. Can U send a picture of what it looks Like ?
yes, Caterpillar, I will send it later this afternoon, I must open the drill and I out of the house. Thanks.
HiltWpg, thanks for your answer, I will do it later, I’m out of the house and I will let u know.
Hi HiltiWpg, I did the test for armadure, testing the windings and the ohms reading 180 degree was 0.05 ohms in everyone. What I must do next… thanks
engiab wrote:
New armature I would say . if do u mean 180 degrees f ?
Try this, it may help.
Thanks HiltiWpg. Yes, I used this video to do the test and gave me 0.05 ohm between each opposite position(180 degree) windings. Following the instructions look like my armature is good (it is not in short).
Hi Caterpillar, I found the makita armature replacement price, It is cheap. I will by one and let u know. Thanks.
