Multi-bit screwdrivers vs. individual
dwasifarMember since Dec 2016
Who’s up for a discussion on multi-bit screwdrivers vs. individual screwdrivers?
Every time I see a nice screwdriver set, I immediately want them; but I know from experience that I’m not gonna use them.  Instead, I’m going to grab one of the 7-in-one or 9-in-one drivers I keep strategically scattered around the house.  This is why:
Pros:
  • Less to carry around (can stick it in a pocket)
  • Chances are better that the tool already in my hand is the tool I’ll need next
  • Fewer individual tools to lose track of while working (this is a real problem for me, and it’s not a senior moment thing either, I’ve been saying “I JUST had that, where did it go?” since I was a teenager)
  • Individual bits, or the center shaft, can be chucked into a drill, so I don’t have to carry around a separate set of driver bits for that
Cons:
  • Sometimes too bulky to reach recessed screws
  • Bits can dislodge on impact
  • Not good for prying (paint cans etc.)
For me, apparently the pros outweigh the cons, and I standardized on the multi-drivers.  It wasn’t a conscious thing, it’s just something I found myself doing over the years, and it took me a while to think through why I was doing it.
These are my current go-tos:
Photo from the original forum    Photo from the original forum
I’ve been using those Crescent ones for ages, and they’re really comfortable; I have a bunch of them.  But they don’t make them anymore, so I’m trying out the Irwin, and it’s really nice too; good feel in the hand, more bits and options than the Crescent, and it feels like the Phillips bits grip the screw a little better.  Greenlee and Lenox sell the identical tool under their brands and color schemes, but I prefer the bright colored Irwin because of the aforementioned “where did I put it?” problem.
Did I miss anything?  Contrary opinions are welcome.
Definitely need to have both. They are a must in any tool bag or garage.
Try Wiha …. you won’t be disappointed. A different style, using the smaller tips….
worth looking at
Wera James Bond driver hands down the kk20
Okay I’m done pushing the KK20 lol
BremonMember since Dec 2014
I like multibit but I will never go back to not having individual drivers as well. Well, unless my future involves living in a tiny house. I’ll forever have both though. Multibit for truck, garage, junk drawer, etc. and full set for in the workshop.
Gotta have a full set well multiple full sets lol the think I love about the KK20 it fits in the pocket so if I run in to a house to check it out a potential job I have a screw driver at hand.
Your craftsman box ought to be green Jimbo! That’s how envious that drawer of black/yellow/red tools makes me!
I was just thinking I should have got the black but I love a red tool box
Yeah, I don’t think I would like the Wera or Wiha, because it’s not the kind of design I prefer.
Both of those make you open the handle and fiddle around with little individual bits. The Wiha looks especially fiddly in that regard; it looks like you have to take a cap off the handle, put it down, and turn a selector dial to access the bit you want:
The Wera avoids that problem, but instead you have to push the bits back into storage clips:
Neither of them have nut drivers, either.  The one advantage I can see to these designs over the center-barrel design is that the bits are generic and can be replaced individually when they wear out.
Compare how the Irwin is designed:
To change bits, I don’t have to open any storage compartment; usually I just need to flip the bit, or flip the center barrel.  Takes about two seconds.  There are three nut drivers.  And I can pull the barrel out of the tool and chuck it into a drill to have an instant power nutdriver or screwdriver, without carrying around separate bits and accessories for the drill.  The Crescent is similar.  I just think this style is a more versatile design.
The downside is that once you round off the Phillips bits, that’s pretty much it for the tool.  I have occasionally touched up a Phillips bit on a grinder to restore the corners and make it grip a little better, but you can only do that once or twice.  Fortunately the bits on both are pretty durable.
Having said all that, I would totally buy a Wera if it were this kind of design.  The Wera drivers look like amazing quality.
If you want one with nut drivers Klein is a strong option
I like my Wera but I almost always use a regular screwdriver. I use a bit holding Wera screwdriver with 4″ bits for hex/torx/security.
[External image (www.toolstop.co.uk), not copied]
I tend to shy away from multi-bit drivers. No real reason aside from preference though. I have sufficient fixed blade drivers in the shop and I have an assortment in my mobile kit, so that covers most uses.
I do use my Mac ratcheting set a lot, and I have a multi in my coaches bag for working on helmets and shit, but given the choice, I’ll reach for a fixed blade.
phffterMember since Mar 2016
i have large quantities of both, fixed,  and multi.
multis spread out thru the realm.fixed, everywhere.
i have fixed and (2) klein multi in my work toolpouch, i rarely grab a multi
rfwjrMember since Jul 2014
I have both but my wife bought me a Kobalt Double Drive for Christmas a few years ago and I thought gimmick. But I find myself grabbing it every time I needed a screwdriver.
I have many many multi bits but if you check the cleanliness of my hands my laser tip weras are the dirtiest
My Weras are also the dirtiest but I use my PB Swiss more(That’s what’s in the tool bag). I think the Weras just show more dirt.
HiltiWpgMember since Sep 2015
I like to think I am very qualified to give some advice on multi bit drivers.
 Other than my insulated set, my Multibit is my go-to.
I try my best to keep the weight down in my service bag and backpack. My long reach Klein 15-1 and Wera Kraftform Kompact 28 and my everyday carries. I carry a flat Wera demo driver with a conduit reamer fastened to it, this serves all my prying and chiseling needs. Everyone should own a Multibit, that have come a long way and are very reliable.
I currently own the following:
Klein 11-1
Wera Kraftform Kompact 26
Klein 15-1 Classic Multibit
Milwaukee 10-1 Multibit
Milwaukee 11-1 Multibit
Klein 4-1 Electronics Screwdriver
Picquic 6 pack
Klein Stubby Multibit
I think I have a problem, I didn’t realize I owned this many…
Hope this helps.
Here is the condensed version:
Klein 11-1
This is the best overall Multibit. Cheap, easy to get replacement bits. Good comfortable grip and decent weight. Fastest bit change.
Hands down the lightest, most comfortable grip. Bit holder is awkward and makes tight space screw access impossible. That’s why I bought the 28. You can use the bit holder in your impact. Folds down for compact portability.
This is my favorite for two reasons, comfort and grip.
Not the fastest bit change but gets into tight spaces and you can remove the bit holder for use in your impact. Folds down etc.
This is my second favorite and the only one that feel like a traditional screwdriver. Weight is excellent and has a nice long reach.
This thing is a giant piece of crap. It’s a poor Picquic knockoff and the heaviest of them all. Bonus points for being able to use the bits in your impact though. It feels bulky and clumsy in the hand, balance is awful.
 Bits are very soft, rounding easily.
Milwaukee 11-1 Multibit.
I had high hopes for this thing. Very disappointed. It’s a bad Klein knockoff.
The most irritating thing is that it’s soooooo short. It doesn’t reach into the back of a standard deep box. It’s almost comical just how short it is.
It’s very heavy and not as comfortable as the Klein.
This is the best controls Screwdriver. I love this thing.
 Klein hit a homerun with this one. A quick change multibit controls screwdriver was the one tool I didn’t know I needed. Now that I have it, I bought a second one and put it away just in case mine goes missing!
Picquic 6 Pack
More of a homeowner tool. I bought two of them.
I dropped the first one and bit holder fell out of the plastic handle.
Dropped the second one, guess what happened? The bit holder fell out again. They never go back in right and keep falling out.
Same as big brother, fast bit change, nice weight and comfortable grip.
mtnkid85Member since Jun 2015
Working in the shop or on vehicles I usually use the dedicated screwdrivers.
But at work (Im a paint contractor) I always have my Wera kompakt 28 on me!  I love having a multi bit driver with me that takes a standard 1″ bit, so that I can swap bits from it into my impact driver when need be.
Because it never fails when your two stories up a ladder some sorry sucker just had to use two different screw profiles to attach that shutter!
Klein 11-1
Picquic 6 pack
I think I’ll get one of those Klein 11-1’s on your recommendation.  It’s designed a lot like the ones I already like, but with Torx. 🙂
rfwjr wrote:
Do you actually use the ratcheting function?  I’ve never been comfortable with ratcheting drivers.
A lot of times when I look at tools like this I find myself just sort of generally marveling at the amount of thought and engineering that goes into trying to make a classic tool better.  I remember multi-drivers from 30 or 40 years ago (yes, I’m that old), and they were nowhere near this good.  They were sloppy junk, mostly.  And most people’s screwdrivers looked like this:
I know this is a classic, and perfectly usable, but I doubt any of you Wera guys would go back to that design, would you?
Or, if you were a cheap-ass like my dad, they came from the 29¢ bin on the hardware store counter and looked like this:
My dad hated Phillips screws – what he called “crosshead” screws – because he was always stripping the screwhead or the tool tip, and he couldn’t grind a new edge onto a cheap Phillips driver the way he did with the cheap slotted drivers.  I eventually realized his problems were due to the cheap tools, but it took me a long time to get there because he would always tell me “It’s a poor workman who blames his tools.”  I finally understood that’s only true up to a point, which eventually culminated in ME teaching HIM about the merits of Phillips over slotted, which was an interesting conversation.
But I digress.  My point is that I feel like we’re living in a tool renaissance right now.  The market is bursting with new ideas for tools, and new refinements of classic tools; even a simple screwdriver has dozens or hundreds of choices, all competing on their merits and quality.  I feel spoiled.  Don’t you?
dwasifar wrote:
Then maybe you have never used Rolgear?
[External image (www.rack-a-tiers.com), not copied]
.. It’s not really “ratcheting” in The sense that you have the clicks of a ratchet, it must have a ball and ramp and is infinitely variable unlike a ratchet and is extremely smooth and very little resistance to turn.
That’s all I’ve been using for a few months now, I can’t recall the last time I used a dedicated screwdriver…
You use one bit to push out another bit when you swap. I carry it in my everyday box and have nut drivers handy to pop in the 1/4″ end when I need.
The unbelievable smooth action is why I love it and is the only thing I’ve been using since Rob from Turbo Plumbing and Heating on Instagram sent me one. I have been meaning to buy some but have been putting that off
dwasifar wrote:
10 hours ago, dwasifar said:
…….I feel spoiled.  Don’t you?
Yes, very!
I still have my craftsman USA set but the tips are hard to compete with the German stuff
dwasifar wrote:
I do actually use it.  I did not think I would when I got it.
I use my M12 Fuel screwdriver or impact for a lot of it, but including a few nut drivers, I probably carry 15 screwdrivers in my main bag with me, which is never far from my side. I own plenty of them, but I just have never found the benefits of a multi-bit to outweigh the detriments, personally. I do like my Megapro as a house junk-drawer screwdriver, but that’s about it.
fm2176Member since Feb 2017
sparky603 wrote:
I have a number of multi-bit drivers, from the Double Drive (regular and stubby) to the Klein 11-in-1 and various Milwaukee and other versions.  Also still have dozens of regular screwdrivers made by Craftsman, Snap-On, Matco, and other manufacturers.  That said,I find myself using the DeWalt 12v or 8v screwdrivers more often than not.
Cr8ondtMember since May 2016
I don’t normally use human powered screw spinners but when I do I use these:
Multi bit ratchet driver: Crazy over priced Snapon, I absolutely love it.
Regular drivers: Craftsman US made, not the best in the world but damn well decent.
I decided to give individual screwdrivers another go, based partly on what people are saying in this thread, and partly because having a real tool chest (as opposed to random tool boxes) for the first time in my life is already changing how I work.
I know you guys are are gonna be disappointed that I didn’t buy the Wera set, but I decided to go Made In USA instead:
I considered Craftsman, because the classic clear handled ones are still USA, but for how much longer? I decided I trust Channellock more at this point. $50 shipped from Circle C. Arriving Wednesday. If I wind up switching to single drivers, then I might consider the more pricey Wera.
those are some nice drivers, i have a set of USA craftsman but i hardly touch them, still love the feel of them though just hard to fight the tip of a wera
I was just out in the garage making a rack to put them in when they arrive.  Channellock is nice enough to give precise dimensions for every driver in the set, so I can make the rack in advance and have it ready.
dwasifar wrote:
Here’s the rack, all ready to accept the drivers when they arrive:
DerekTheToolGuyMember since Nov 2016
Im all about my Snap on soft grip and hard handle ratcheting screwdrivers they are top notch and they best I’ve used. I do have some (insert number) in one screwdrivers like Ideal and klien but just not a fan of those. My favorite is either my green soft grip or my (holy grail) clear hard handle I rally enjoy using them but find myself using my mini snap on screwguns often as it saves the wrist.
I have both, I do like a good multi bit,Waiting on a new Wera Kraftform Kompakt should be here Tomr , I have Wiha also. As soon as you pick one up , whether it’s an individual or multibit you can usually tell.
Foneguy wrote:
The Wera without the internal bit storage doesn’t have that bit driver feel. I love using it because it feels like a screwdriver, I have a small pouch with a full set of security SAE hex, security Metric hex, security torx which obviously double as non-security…and some other bits I rarely need, all the bits are 3.5″ so they feel like a regular screwdriver.
FrosBros82Member since Feb 2015
I have both personally. I think there are advantages to both. On the site I tend to have multi bit, as I never know what I am going to get in to. In the shop I have screwdrivers everywhere. I don’t really think you can go wrong either way, more of a preference and depends on what trade you’re in.
Got it today !!!
great feel to it
shout out to my man Ryan @KC_Tool
Great service always !!
Foneguy wrote:
5 hours ago, Foneguy said:
Got it today !!!
great feel to it
Awesome, I’m partial to my Rolgear but I have been thinking about getting a Wera ratcheting one…
I love how silent and smooth the Rolgear are: honestly nothing comes close for ratcheting screwdrivers
I was looking into a rolgear also, then i saw your post on IG.. & I said DAMN !!!! Homeboy got a pretty impressive grip to smash that with his bare hand…… then I read the post. I will more than likely pick one up, can’t have too many tools!
but I am slowly expanding my hand tools into the European brands, and so far I am not disappointed.
Ha yeah I’ve turned it on some very tight screws and couldn’t break it but it dropped square on the cement and it’s toast!
I was a little mad at the guy that dropped it when he was carrying things off the roof, but we have a tool purchase policy at work and they will replace it for me
[External image (farm5.staticflickr.com), not copied]
