Knipex flush cut pliars
Question for the Knipex guys.  What model is the largest flush cut pliars that Knipex makes?
Thanks
Probably a 7″
Good question for Ryan at KC send him a PM
I think Jimbo is right.
Yea I don’t recall any flush cuts with a model number ending 250…
Yeah, most are 160mm to 125mm.
You can go through all their cutters on the left menu, the graphic you’re looking for is [External image (www.knipex.com), not copied]
Looks like 72-01-180 is the largest
KC_ToolMember since Sep 2016
Yep it is. Are you looking for a larger set?
I wouldn’t cut metal with those. They are designed for plastics. I might suggest
74-01-180 even though they cut with a bevelled edge.
Agreed, the truly flush cut is mostly for plastics and leads(on a capacitor or resistor), I don’t even use them on diodes. The Kleins are also double beveled, the Knipex should be a great replacement. I’ve cut (small) screws and nails with my 7″ Knipex diagonal cutters.
