Random service call finds
Brand spanking new house we did plumbing and HVAC, getting ready to install faucets after the counter top guys do their work, it’s that far off center (right side of my level) how does this happen!!
[External image (farm9.staticflickr.com), not copied]
Also at this house:
Gaps everywhere… Trim won’t fit/seal properly
Also later they had water coming through the ceiling below this shower, when the tile guys set the base and glued into our drain line, they butchered the fitting and so it leaked right away…. This is the most expensive, involved house I’ve worked in, but somehow moonlight Joe got the tile job lol
Water heater not venting properly…. Guy going through a divorce says “do the bare minimum” I replaced what was there instead of going all out B-vent…
Sorry for the photo dump, I thought I’d share my journey and maybe provide some entertainment too!!!
I can’t count the number of times I run across these types of hangers and they’re doing nothing… Yeah that’s a nail bent over and was holding the pipe up
I could never be a plumber man, soo much respect
so what are you doing in the picture with your legs sticking up?
Have you ever seen any cast iron pipe full of black sludge type stuff?
Is the last picture plumbers installing shingles?
Ever find any old newspapers, magazines, or anything else hidden in the walls or ceilings/floors? A guy at work found 3 papers from early 1900’s hidden in the ceiling of one of our current jobs.
Thanks Brian, I’m happy to say I like it for the end result and love the variety
I’m down in a crawlspace cutting out some old cast iron pipe to be replaced with PVC.
The black sludge yes, it’s everywhere in the old cast pipe, just from debris build up from washing dishes, washing hands, shaving, stuff going down the drains, catches on the rough interior of the pipe and builds up.
The last pic is just showing what the Grace stuff is meant for, as a comparison.
The newspaper was in a crawlspace, that’s about all i’ve found can’t recall anything else off the top of my head
On 4/15/2017 at 9:25 AM, KnarlyCarl said:
Hole saws are overrated…
looks like the customer gets a free hole saw.
Jronman wrote:
Haha no, that’s a shower valve you’re looking at and someone chopped the opening in the shower wall without using a hole saw properly
So, it’s not a plastic holesaw then?
Mordekyle wrote:
nah, it’s the backing plate for the shower valve
Oldie but a goodyPhoto from the original forum
[External image (farm5.staticflickr.com), not copied]
That is supposed to be a solid stainless band around the pex pipe.
Apparently, the manufacturer is in a lawsuit because it’s happening all over.
If you have this in your house, get it out!!!
