Does the dewalt green laser have a lock function where you can make diagonal lines for hand rails and things like that ?
Never heard of that feature…….I know the pendulum locks when you shut it off
If you have the DW089LG it will not turn on unless unlocked so it can not do angles.
Framer joe wrote:
13 hours ago, Framer joe said:Never heard of that feature…….I know the pendulum locks when you shut it off
Yes some lasers do. I have a green line laser that can be locked off on any angle
I’m referring to the 12v ( 10.8v ) green laser does that one have this feature ?
Craigh9916 wrote:
No it doesn’t
does the 20v laser have this option?
This is incorrect.
The DeWalt green lasers cannot be locked and set St an angle, however, when on and set at an angle the lasers will project the angle desired.
The only thing the laser does is periodically blink multiple times to let you know it is out of level (~30 seconds solid then 3 blinks then ~30 seconds solid).
It works, I’ve done it. So have others.
The.Handyman wrote:
5 hours ago, The.Handyman said:
This is incorrect.
Nice to see the warning flashes prevented me from using it like that worried about hurting the pendulum.
Is there a 20v laser then ?
The 20v laser is a large square rotary laser.
The.Handyman wrote:
On 19/03/2017 at 5:00 AM, The.Handyman said:
This is incorrect.
Just tried this with my DCE088D1G and while you can strike a line on an incline, the flashing warning happens more frequently – 3 flashes and a solid beam for 5 or so seconds.
