“… not rated for a vehicle…”
[External image (static.comicvine.com), not copied]
Hugh Jass wrote:
7 hours ago, Hugh Jass said:“… not rated for a vehicle…”
that sucks, i have been looking at these for my van, figures,, that would have been too easy
I don’t see the point of using this outside of a van. I would build some kind of sysport (https://goo.gl/images/A5Nzxu) instead if I was working from my shop. The rack is better in a van because it is lightweight and takes no space when you are not using it but I see no reason to use it in a shop.
mohawkdec wrote:
1 hour ago, mohawkdec said:that sucks, i have been looking at these for my van, figures,, that would have been too easy
At least they are telling you up front, not to do it. I am sure when they show up on HomeDepot.com , some idiot will install them in a van and rate it one star and tell folks why it was unsatisfactory for the job.
There was another thread:
that mentioned them with pictures, and a description of the differences in the brackets (on page 2). From what it sounds like the brackets are lighter because they won’t be moving like on the trolley/ hand truck and taking abuse. I also think the vertical tubes come in multiple pieces instead of one piece tubes (it makes it easier and cheaper to ship with a 2 1/2 foot box instead of one 5 feet long. So the strength would be compromised there too.
mohawkdec wrote:
2 hours ago, mohawkdec said:that sucks, i have been looking at these for my van, figures,, that would have been too easy
I think it is more of a liability issue. If they would brake loose in a accident and come flying forward and hit the driver or passenger they don’t want the liability and dodge the lawsuit.
I could see them working well in a job trailer even though they are not vehicle rated
I thought about using them for inside my bedroom closet since I like to keep my batteries inside.
regopit wrote:
6 hours ago, regopit said:I think it is more of a liability issue. If they would brake loose in a accident and come flying forward and hit the driver or passenger they don’t want the liability and dodge the lawsuit.
i dont know, when i bought
my van i had it outfitted with 3000.00 worth of adrian steel shelving units, nothing is secure there i have bungi cords all over keeping things on the shelves. I want to take one side off and use the the tough system, i guess ill just have to bite the bullet and make my own. ill just need more beer
You can do what you want. If you want to put them in your van or trailer it on you to make it work and DeWalt takes no Liability.
You can get them now at the Tool Barn http://www.toolbarn.com/dewalt-dwst08260.html?psrid=226090146 or at Amce Tools http://www.acmetools.com/shop/tools/dewalt-dwst08260?cm_mmc=Affiliate-_-SaS-_-290560-_-619300 For $99.99
I know I have posted it before but we just use 2 10″ heavy duty angle brackets. We screwed them right to a piece of 3/4″ osb in our van. Welded a tab to keep the boxes in place. Cheap and heavy duty. [External image (uploads.tapatalk-cdn.com), not copied]
is it possible for the side handles to open up just enough to where the box could vibrate off of the rack during travel in a van or trailer?
Big disappointment…….DeWalt cheaply made the brackets for this wall mounted system
snohiker wrote:
On 3/10/2017 at 10:12 PM, snohiker said:
I’ve had theses two in there for almost two months and nothing hit the floor yet got two more going in soon totes on one side hardware and tools on the other
77Ford01 wrote:
17 hours ago, 77Ford01 said:Big disappointment…….DeWalt cheaply made the brackets for this wall mounted system
Yea I wasn’t to happy about that the ones you see mounted now need to collapse so I can fit geo thermal units in the trailer so it looks like I’ll be spending some cash on brackets , if you notice tho they show the good brackets in the video
Jronman wrote:
On 3/10/2017 at 11:17 PM, Jronman said:is it possible for the side handles to open up just enough to where the box could vibrate off of the rack during travel in a van or trailer?
I don’t think the handles would open at all with the springs holding them in place
