Planex Mod
So this isn’t my idea. I have seen several guys add led tape light to their Planex. This makes great sense. Thanks to those guys for the original idea.
I didn’t want the wire running all the way down the tubes and I didn’t want to tap into the power of the Planex at all and blow the warranty.
I saw these led lights with USB ends on them. We have Bosch 12v batteries. I ordered an $8 light strip from Amazon and a Bosch 12v heated jacket holster. The holster puts out 5v 1amp through the USB port.
It didn’t work right away. Not sure why. I think maybe something with the holster. It has an on button for the USB that you have to hold for 3 seconds. After fiddling with it for awhile it now works.
I cleaned the area around the head with lacquer thinner. The strip stuck well. Then a little hot glue to hold the wire solid on the head.
Right now just a zip tie holds the holster on the unit. You have to remove the holster to put the Planex back in the case so this seems to work. It lights up around the head nicely.
Milwaukee has a similar holster for their 12v batts and Dewalt makes one for their 20v so this can be made to work with whatever battery platform you want. I like the smaller size and weight of the Bosch or Milwaukee.[External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied][External image (uploads.tapatalk-cdn.com), not copied]
Wow Andrew, thanks for sharing that, I don’t have the Planex but that would be a fantastic idea on my drill press!
ChrisK wrote:
Yes !!!! Thinking this would be way better than the crappy tiny light bulb
Dude…….  BRILLIANT !!!!!!!
That’s awesome, I’ve seen this done before it’s a sweet mod
That’s slick, saw that floating around on the IG, and I think all tools should come with lighting to light up the area of work, corded tools also. Like what Bosch did to their starlock OMT.
I think they should put lighting in toasters too haha  They have a light in the microwave, and oven, why not toasters, and blenders and coffee pots LOL
ok I’ll just put in under cabinet lighting and stop complaining 😀
ok I’ll just put in under cabinet lighting and stop complaining [emoji3]
LEDs are cheap enough it shouldn’t add much production cost
sent from tapatalk
rrich1Member since Jun 2015
Matt Cremona did something like that on his band saw.
rrich1 wrote:
Lights? Missed that part, awesome watching that come together!
I saw where he put a drill to replace the hand crank tho
No this was his in the shop bandsaw.
rrich1 wrote:
hmmm im sure that helps tremendously with visibility
