Well yesterday I bought the M18 fuel 15 ga nailer Kit from my HD…
And when I opened it I charged the battery on my 6 bay rapid charger,got a different battery put some 34 deg. 15 ga nails into it and powered it on and it wouldn’t shoot at all the LED didn’t respond either read the manual front to back looked for videos switched batteries and no one seems to have this trouble. so I’m taking it back.
Are you sure it’s powered on? You have to hold the power button down for a while (about 4 seconds), and reasonably hard too. Then a green light comes on ….
dwain wrote:
1 hour ago, dwain said:Are you sure it’s powered on? You have to hold the power button down for a while (about 4 seconds), and reasonably hard too. Then a green light comes on ….
Yes the green light came on after holding the power button for 4 seconds or so…
thanks for the reply though
Assuming you probably already know this, but the tip has to be fully depressed or it will not fire. Or if there are less than something like 5-10 nails, it won’t fire.
Daniel Julian wrote:
3 hours ago, Daniel Julian said:Assuming you probably already know this, but the tip has to be fully depressed or it will not fire. Or if there are less than something like 5-10 nails, it won’t fire.
Yep fully loaded the nailer and still didn’t fire
Anyways got it swapped for a new nailer that works, and that 15 ga sure is amazing I feel cool O0
i would return it and swap with another one
Milwaukee_man_stan wrote:
2 hours ago, Milwaukee_man_stan said:Yep fully loaded the nailer and still didn’t fire
Good deal!
It’s a great nailer!
