I’m not sure I’d want one of those, I have seen what slow moving powerful drills can do I would hate to see what it would do at 8x the RPM….not many variable speed grinders
1 minute ago, comp56 said:I’m not sure I’d want one of those, I have seen what slow moving powerful drills can do I would hate to see what it would do at 8x the RPM….not many variable speed grinders
Better hold on then ?
That’s pretty cool but pretty dangerous as well.
Fletcher94 wrote:
7 minutes ago, Fletcher94 said:That’s pretty cool but pretty dangerous as well.
Agreed
10,000 rpm drill bit [emoji51] good luck
1 hour ago, JimboS1ice said:10,000 rpm drill bit emoji51.png good luck
Lol good for really small bits I bet
Of for a smoke show ha ha
welcome to our flying grinder show….not to worry they are tethered with the power cord. If you pay for the deluxe tickets we will be doing some trick with a cordless……..
3 hours ago, comp56 said:welcome to our flying grinder show….not to worry they are tethered with the power cord. If you pay for the deluxe tickets we will be doing some trick with a cordless……..
i would watch as long as I am a distance away 😉
jeffmcmillan wrote:
1 minute ago, jeffmcmillan said:
Very cool where can u get one at ?
CATERPILLAR wrote:
2 hours ago, CATERPILLAR said:Very cool where can u get one at ?
Order on Ebay, Amazon, or MadeinUSAForever.com.
For sale is a simple three piece machined steel collet-spindle adapter for angle grinders providing flexibility of application and work area, ergonomics in operator comfort by providing two hand operation, safety in lower operating speed, reduced cost as an additional electric or pneumatic die grinder and expensive air compressor, hoses and filter regulator are not required. Simple machined design allows for rapid change over and small size (2.125″ Long) allows for easy toolbox storage.
The adapter allows the use of all 1/4 and1/8 inch die grinder tooling on all angle grinders with 5/8-11 male threaded spindles. Including wire brushes, carbide burrs, cartridge sanding rolls, rasps, buffs, “Speed-Lok” type discs of various diameters, aluminum oxide mounted points and “RotoZip” bits with a 1/8 inch adapter. (See photo for the various tooling used.) Requires only a spanner wrench and one or two 3/4 inch wrenches for installation and tool changes.
Use your DeWALT 4 1/2″ cordless or 110 volt angle grinder to cut and deburr up to 1″ conduit in less than 30 seconds. Uses a 4 1/2 or 5 inch cutoff blade, 1/4″ mandrel, and tapered 80 grit cartridge sanding roll. Not included or add $5.00 (our cost) for a starter kit (4 1/2″ blade, mandrel, and cartridge roll).
Beware of hex designs that can damage soft work pieces.
Overengineered, CNC machined, heat treated, and black oxide plated to last a lifetime. Priced less than half the cost of a quality pneumatic die grinder. Replacement nuts and collets available. Made with pride entirely in the USA. Dealer inquires welcome. Grinder, tooling, 1/8 inch adapter, and wrenches are not included. Buyer pays shipping. ALWAYS WEAR EYE PROTECTION AND PERSONAL PROTECTIVE EQUIPMENT WHEN OPERATING. US PATENT No. 7,717,771
Interesting but I really can’t think of why I’d personally need it. I can’t think of something where I’d need this over just using my Milwaukee rotary.
Congrats man ???
