“New” old battery – Problem?
mddMember since Jan 2017
I just received a new DCD795 drill, purchased through Amazon.
While opening the box, inspecting things, ohhing and ahhing (first new drill since my 14.4v), I noticed the batteries and drill are dated 2014.
Now, the drill doesn’t bother me too much as it’s clearly unused, and given the years of use from my 14.4, feel it will serve me for a number of years. The batteries, on the other hand, I do question. Would a two year old, never used battery, purchased new, bother anyone here? How much life/run time do you think it’s lost sitting in the box?
Any thoughts on this are welcome.
Thanks.
As long as they have never been used and abused, lithium cells are very durable, save your receipt because if they fail you do have a warranty on them as well
Like Jimbo mentioned make sure you keep you receipt as if you don’t the base the warranty on the date code on the battery
Truthfully if they were stored properly at the correct charge cap, the batteries should be fine. They are lithium and do not have the memory issues of old. And…..just like Jimbo said…..then DR said….. 😀 keep the receipt!
Oh yeah! WELCOME TO THE FORUM!
Congrats on your new drill…and welcome …I thought lith ion batteries drained some even if not used , I read it somewhere on here…but I’m not sure….and as they all said….keep your receipt….
Lions will still self discharge but even with 1/2 a charge companies do you should be ok from under voltage. The only company I heard having issues with under voltage were old Makita lxt packs and that only happened it you ran them down to empty.
Cr8ondtMember since May 2016
I have well used batteries from 2014…. I plan to well use em for years to come ?.  Agreed keep your receipt or just know how to look up you purchase history from Amazon because DeWalt definitely uses the date code otherwise.
Jrhky36Member since Nov 2016
Lions will self destruct upon the opening kick off. Thankfully their season is over
Jrhky36 wrote:
wait what? they explode?
Jronman wrote:
Might as well have……. Lions fan here, unfortunately…. I digress…….
Cr8ondt wrote:
oh you were talking about sports haha. literally thought you were talking about batteries.
Jronman wrote:
I knew what you ment, but yes batteries can explode, no you don’t have to handle them like eggs but ask any Samsung phone owner if they truly feel safe.?
li-ion batts can also swell and catch fire haha.
Thanks for the input. Interesting, I expected more red flags on this, especially a two year old battery sold as new. No problem saving the receipt, as I was taught from an early age to save all my receipts. I wouldn’t be surpprised if I still have receipts from toilet paper dating back decades.
Thanks again.
Boeing had issues with batteries on the 787. It forced them to ground the plane until the battery issue was solved.
Some think exploding li-on batteries were the cause of that plane that crashed in the Indian ocean
Problem is when they are over heated as in cell phones under a pillow, part of the samsung wireless charger issue was a malfunctioning regulator which allowed the battery to keep charging and overheat
