Milwaukee m12 Bit Holder
There isn’t one. I used a clip and drilled a hole through it, then screwed it into the belt clip screw.
vaultmanMember since Feb 2014
Like a binder clip?
vaultman wrote:
3 minutes ago, vaultman said:
Like a binder clip?
A bit holder clip. They come out of the plastic rather easily. Anything that holds bits like that Milwaukee clip you posted.
You might be able to use a binder clip if you can find one small enough, haven’t tried myself.
Ah. Yeah that is a little more understandable. I think I will try the one you mentioned. Thanks.
I suggest screwing a magnet to it instead so you can store a couple bits and not just 1/4 hex ones.
