I have an older 3/8 drill i am thinking of making a mini drill press with so when you are using very small bits they dont break and it would be kind of cool. Do you guys have any ideas how i can go about doing this i am thinking of wiring the switch so i can pull the trigger to go speed i know they sold little things like this but i want to try to make some 🙂 thanks for checking this post out have a good one
CATERPILLAR wrote:
1 hour ago, CATERPILLAR said:I have an older 3/8 drill i am thinking of making a mini drill press with so when you are using very small bits they dont break and it would be kind of cool. Do you guys have any ideas how i can go about doing this i am thinking of wiring the switch so i can pull the trigger to go speed i know they sold little things like this but i want to try to make some 🙂 thanks for checking this post out have a good one
You’ll probably be in less money by just buying a Rikon bench top unit. Me and @ChrisK each have one and like them.
CATERPILLAR wrote:
I have an older 3/8 drill i am thinking of making a mini drill press with so when you are using very small bits they dont break and it would be kind of cool. Do you guys have any ideas how i can go about doing this i am thinking of wiring the switch so i can pull the trigger to go speed i know they sold little things like this but i want to try to make some [emoji4] thanks for checking this post out have a good one
I have one of these it’s a good alternative and beats fiddling with a homemade press, I was going to make one but got a gift card so why not??
That looks pretty slick Jimbo. Do you just press it down to advance it or how do you plunge it?
kruton wrote:
13 minutes ago, kruton said:That looks pretty slick Jimbo. Do you just press it down to advance it or how do you plunge it?
yup hook up your drill, you can angle it or straight and push, there is a depth stop, on the base you can use it to drill center holes or even mount it on the under side of a table for sanding drums, pretty cool i have a video for it just have to edit and upload, has a few quirks but for 25 bucks its the same as the 40 dollar rocker one, not bad
pretty cool idea but that defeats the purpose if it i am making one from scratch 🙂 thanks for stoping by have a good one
The best advice I can give you is hose clamps. Lots and lots of hose clamps.
jeffmcmillan wrote:
16 hours ago, jeffmcmillan said:The best advice I can give you is hose clamps. Lots and lots of hose clamps.
lol 🙂 very useful thing hose clamps kind of like duct tape but not
