So my dremel 3000 shaft is starting to get stripped and I cannot take out the sanding drum. I’m looking at the dremel 4200, does anyone have an idea on how well they work and would anyone recommend me a better corded rotary tools if so, I need your help.
Sent from my XT1080 using Tapatalk
The collet nut is stripped? Replacing it would be a lot cheaper. I’ve heard the quick release has some bugs.
The shaft lock is slipping when I press it down and try to unscrew the collet nut.
Is there no other way to hold the shaft from spinning such as a pair of pliers?
No expeierence on the newer dremel I still have a 400xpr but don’t use it much, it needs brushes, I pretty much replaced it with the cordless Milwaukee rotary
take the dremel apart and get a pair of pilers and grip it on the shaft coming from the motor and turn the nut off had the same probelm with my dremel 3000 🙂 have a good one if you have anymore tool repair questions just pm me
