Diamond grinder blades for metal
I haven’t seen the Milwaukee steelhead ones available anywhere yet, but there’s a Ridgid version that looks identical (down to the arbor knockout) from home depot already plus a lenox equivalent on amazon.
Has anyone tried these?
I’m really hopeful that these handle wood ok so you don’t have the fire risk of cutting metal flush with wood.
[External image (www.toolup.com), not copied][External image (www.homedepot.com), not copied][External image (images-na.ssl-images-amazon.com), not copied]
Wow they do look identical.  Haven’t tried any of them.  I have a Bosch and it does good.  Not sure how it does when flush cutting with wood.
M80Member since Oct 2014
I have the Lenox blade. I am happy with its performance so far.
pancingMember since Jul 2016
does the blade heat up fast? I wonder how good these are cutting rebar
pancing wrote:
There is a little video on home depot.com that shwos it cutting through a couple things and it cut through rebar pretty good . They claim that it one rigid metal disc=70 abrasive cutoff discs
SlingShotToolsMember since Oct 2016
Without question the Lenox Metal Max is a beast.  Cuts through darn near anything with virtually no sparking.
SlingShotTools wrote:
were do you get the lenox blade ?
JMGMember since Dec 2015
Lowes carries the lenox blade in my area. Was looking at it two days ago when I was picking up a dry cut blade.
CATERPILLAR wrote:
Hey CATERPILLAR, we have these on back order at SlingShot Tools.  But in the interim, check out your local Lowes store.  They just started carrying them as well.  Good luck and hope all is well!
Thanks man i will check it out but first i got to buy a 4.5 grinder i have a 4 inch,5inch9inch but not a 4.5 lol will probably get a makita:) have a good one #tiacrew
JMG wrote:
Thanks for responding hows the blade 🙂 have a good one #tiacrew
CATERPILLAR wrote:
My Lowes has the lenox blades in a lot of sizes, at least 4 and 5 inch.  Maybe 9 inch too.
jeffmcmillan wrote:
shhh that will give me an excuse to get another tool 🙂 have a good on Happy Halloween #tiacrew
