M18 Fuel case.
DannerMember since Aug 2016
Hi, I’m trying to found a case for my M18 FPD,
in ebay there many kind of suit for milwaukee M18.
So, I found a case for a M18 Fuel CPD, is anyone can confirm this one is suitable with my drill tool ?
Thanks.
BremonMember since Dec 2014
Seems like European and Australian model names for the 2704 Fuel hammer drill from what I can find in a 30 second Google search. Should be the same.
Edit isn’t working worth shit, so here’s my edit: CPD 402 however I think is the first gen 2604 which is larger than the 2704. We may need more info from you, a number. CPD seems like a catch all term for hammer drills, just like Dewalt drill driver models all seem to start with DCD
yes, the M18-CPD is replaced by the M18-FPD.
But they don’t have the same size.
So if you or anyone can confirm I will appreciate.
(CPD and FPD are european models)
Based on the torques listed on amazon.co.uk CPD is the 2604 and FPD is the 2704.  The 2704 (FPD) is the same or smaller in pretty much every dimension so it should fit in the 2604 (CPD) case but might rattle around a bit.  The side handle I recall being a bit longer though so that might not fit.
ok thanks, I’m groing to found another case
