New RedLithium batteries
BremonMember since Dec 2014
Update from one of my favorite Canadian suppliers (BC Fasteners).
M12 3.0, M12 XC6.0, M18 9.0HD available September 15
M18 XC6.0 available September 30
of more interest is charge times:
battery/rapid time/standard time
M12 3.0 – 65 min / 70 min
M12 6.0 – 90 min / 130 min
M18 6.0 – 68 min / 124 min
M18 9.0 – 95 min / 180 min
All I have to say about that is that rapid chargers better become standardized across their entire lineup and they can put the old ones out to pasture, or stick them in the crap kits with the budget brushed stuff because with the competition using fan-cooled high current charging these times look pretty pathetic to me.
Definitely need a rapid charger
I still can’t believe the pricing. For $25 more you can get a pair of 5.0 instead of one 6.0.  At least the 9.0 gets you increased performance and roughly the same runtime as the two 5.0.
Bremon wrote:
This could be the reason:  Here in europe at the least every battery that has a higher capacity then 100 watt hours ( 18v * 6 Ah =  more then 100 wh ) falls under a law that states it is an ‘dangerous amount of lithium’ .  Every battery with more then 100wh  needs spezial packaging, special labeling, some precautions for transport, more paperwork… blah blah blah.    And this all drives up the costs.
6 amp batteries are alot more expensive then 5 amp batteries here in belgium at least and that is because of that law 🙂
I’m not sure if you have a thing like that in the USA  but if you do, good chance that drives up the costs 🙂
Thanks for the info korno, I imagine Canada follows the US lead on that, and that’s probably the case.
