What parts need to be inspected/replaced on a used drill?
YogMember since Aug 2016
I got myself a used,beat up Makita BHP452 from ebay for my house reno project. It works, it drills. This my first drill…. what do I need to look out for on used Hammer drill, currently they have sparks coming out of the rear cover. And it seems to be having a “braking sound” (short screeching) whenever I stop drillling, Is this normal?
I like taking care of my machines, I cant help it, especially if they serve me well.
Thanks for any tips.
If anyone want to get a used Makita in 2 months time, I’ll be happy to sell. Ha ha!
BremonMember since Dec 2014
Sparks are normal. The braking sound is also normal I would guess. Only thing to really watch out for are the carbon brushes, and they go infrequently and are cheap to replace.
OK, just the brush. I got scared of the screeching brake sound cause I have my friend’s corded AC hammer drill, and they slow down gracefully.
Thanks for the tip.
Theres an electric brake when you release the trigger which is probably what youre hearing but it should sound more like a clank than a screech but it depends how fast you release the trigger.  The sparking is probably normal but its worth pulling the back panel to check the brushes. The back panel is separate so its two screws and easy to put back on.
I dont know why you’d plan to sell it. Mine is still chugging along nicely.
Finally, ah fellow BHP 452 user. It works fine. But would probably have no use for it after my renovations complete. So, it is a brake… that’s nice to know.
PusheadMember since Sep 2015
And about sparks, when you inspect carbon brushes, you should also inspect that springs that push brushes are ok. And its good idea to lightly sand copper collector with P240 paper.
Had it inspected at a repair center specializing in makita drill , turns out Jeff and Bremon were right, I let go too agressively. Apparently its in good working condition… with heavy cosmetic wear.
AndriusMember since Aug 2014
Check carbon beushes and check armature ball bearings. And when you take motor apart check yoke unit for dust or some dirt on it. Clean dust from switch with air compressor. Then check if your chuck not moving from gear assy, because its ball bearing inside and some times its need to be replaced. And clean batterie contacts for dust for good connection with batterie. If you will burn it I can buy it 🙂
Wow, thanks for the tips. I knew somebody will know something, this is really useful! Thanks
just fixed one brushes , gear box switch
