Is there max size for screws for an impact driver?
AlkisMember since Jun 2016
What the title says! Been searching around the internet but did not find any answer.
Thanks
No, I’ve done 1/2″ X 6″ lags with my impacts
Edit: depends on the torque rating as well but you should have an issue at all with screws, even 3/8″ lags up to 8-10″ it’s when you get the bigger lags you can max your torque out but pilot holes help with that but for just screws that’s the beauty of an impact is it’ll keep driving the screw in
The only thing you might run into is a phillips screw might want to cam out even with an impact driver. The other drive styles help with that.
Philips are garbage, great point I use Torx or Robertson square
The answer to this is a most definitely. Even gen two Milwaukees will have difficulty running large self tappers into to pilot hole drilled I beams.
By large I mean 3/16 and up.
I’ve noticed that regardless of size the density of the material you are screwing into and the pilot hole are the biggest factor as long as you can keep the friction down between screw and material an impact driver will work great just make sure you pilot hole is only as big as the shaft that way the threads get a deep enough bite but without the shaft squeezed into the hole.
Shaft squeezed in the hole. That’s what she said
Yep everything in a machine shop sounds dirty tap’s, shafts, nipples, someone might think your shooting a porno.
Basic physics really and compression of the wood, having the pilot hole removed material reduce the amount of compression.
Want to see something cool? Tap some 10″ lags in PT timber with no pilot holes at high rom, compression and density is so high the treatment fluid will boil at the surface
I’ve never done that but I can pictures it the heat that is produced from the friction created from no pilot hole must be so intense but also the strain on the tool has to get really hot also. I completely burnt out the brake on my makita impact gun installing lags when I was still installing commercial skylights
Cheng LiuMember since May 2015
Alkis wrote:
Thanks
There is no official limit, it depends on your specific driver. I once drove 1/4″x6″ lag bolts with mine. I wouldn’t recommend it though as afterwards my impact driver was literally smoking afterwards. Needless to say, next time I do that; either pre-drill a hole or use an impact wrench.
They might not be wrong 😉
