What cordless tools do other brand(s) make that you wish yours did? Also what is one cordless tool that you are glad that your brand makes that others or most others do not? As a member of team lime green (Ryobi) I really wish they would make a cordless wet/dry shop vac like the one that Milwaukee has. Another one would be a framing nailer like the one Dewalt has, although I would prefer if they could make it 21 degrees rather than 34 degrees. One tool that Ryobi makes and no other brand (that I know of) makes that I love is the inflator. It has been very useful for me to do many things from inflating my tires, to inflating basketballs, footballs, soccer balls etc and the other side has been great for things like air mattresses.
Quite a few things but I would like to see Metabo or Bosch make a 180/360 degree lantern like Milwaukee and Makita.
An inflator like Ryobi would be great too.
Good call, that inflator is brilliant, I would love that for pumping up drain line test ball plugs for when pressure testing a system, as well as the pressure on the system itself. I may have to look into getting one anyways, despite my red preference. I do have the ryobi hybrid lights, love them, Milwaukee came out with something similar, but too late. I love that Milwaukee has a plethora of m12 tools, they are my most used cordless tools by a long shot.
I’m not sure of something that makita makes that others don’t but I certainly wish they made a good Brad nailer and that they made finish and framing nailers at all
jswoger1986 wrote:
I’m not sure of something that makita makes that others don’t but I certainly wish they made a good Brad nailer and that they made finish and framing nailers at allSent from my iPhone using Tapatalk
They have a brad nailer but I’ve heard it’s junk
I would like a Bosch 12v rotary tool and a brushless impact driver ( I know that second one exists but I’m not buying on eBay from Korea.)
I want a Ridgid powerboxx (radio that charges batteries when it is plugged in).
I can’t really think of one cordless item that Milwaukee doesn’t have that others do, and that I really need professionally. If I were a carpenter, then perhaps, but they are starting to address a lot of that, too. There’s a lot of things they do make that make me sure glad I didn’t go another route when it was time to upgrade a few years back – I know for certain that I would want to do without my M18 Hole Hawg.
5 hours ago, JimboS1ice said:They have a brad nailer but I’ve heard it’s junk
JUNK 😀 Reaaal fucking junk 😛
Cheng Liu wrote:
13 hours ago, Cheng Liu said:What cordless tools do other brand(s) make that you wish yours did? Also what is one cordless tool that you are glad that your brand makes that others or most others do not? As a member of team lime green (Ryobi) I really wish they would make a cordless wet/dry shop vac like the one that Milwaukee has. Another one would be a framing nailer like the one Dewalt has, although I would prefer if they could make it 21 degrees rather than 34 degrees. One tool that Ryobi makes and no other brand (that I know of) makes that I love is the inflator. It has been very useful for me to do many things from inflating my tires, to inflating basketballs, footballs, soccer balls etc and the other side has been great for things like air mattresses.
Ryobi did have a Canister Wet/Dry Vacuum I have one but it was discontinued and relatively rare. The performance wasn’t that great as it was launched during the nicad Ryobi era. The Ryobi infatoris awesome I won’t give up on Ryobi as a platform I own because of the weird tools like that
For you Milwaukee folks, I know my DeWALT DCE100 blower came with an adapter to use it as an inflater /deflater (depends which port you hook it to, I don’t know what kind of pressure it develops and it won’t work to inflate tires, but it will for air matresses, pool floats and low pressure balls. Does the Milwaukee equivalent come with one too?
Grumpy MSG wrote:
4 minutes ago, Grumpy MSG said:For you Milwaukee folks, I know my DeWALT DCE100 blower came with an adapter to use it as an inflater /deflater (depends which port you hook it to, I don’t know what kind of pressure it develops and it won’t work to inflate tires, but it will for air matresses, pool floats and low pressure balls. Does the Milwaukee equivalent come with one too?
ryobi sells a cordless inflator tool for about 20 bucks. I don’t think the blower could generate enough pressure for that type of inflation, its not an actual air pump
2 minutes ago, JimboS1ice said:ryobi sells a cordless inflator tool for about 20 bucks. I don’t think the blower could generate enough pressure for that type of inflation, its not an actual air pump
It must develop some, it uses a twist lock retention system to ensure it doesn’t blow off due to restriction. If you told me it had a 5, 8 or 10 PSI capacity, I wouldn’t be surprised. I think it’s purpose is to avoid huffing and puffing while blowing something up with your lungs.
I’ve used it in my air mattress and it works really nice but again there is less internal pressure than a tired
1 minute ago, JimboS1ice said:I’ve used it in my air mattress and it works really nice but again there is less internal pressure than a tired
I guess it could be called a HVLP inflator. It wouldn’t take much for any of the brands to adapt a 12V vehicle power (used to be called a lighter) compressor to run off their 12 volt batteries. It’d be cheap and easy.
As for cordless tools, I’d love a DeWALT 12V Max 18 gauge brad nailer and 23 gauge pinners. I would also like the 12V batteries to have the fuel gauges. I know you aren’t suppose to store the batteries at full charge and I remain baffled as to how you are supposed to ensure it is at the right level. I know Milwaukee’s line is a lot more popular and has a lot more tools available, but I like that the same charger works for both the 12 and 20 volt lines.
18 hours ago, JimboS1ice said:They have a brad nailer but I’ve heard it’s junk
I guess that’s why he said a good brad nailer.
jswoger1986 wrote:
On 22/06/2016 at 10:58 PM, jswoger1986 said:I’m not sure of something that makita makes that others don’t but I certainly wish they made a good Brad nailer and that they made finish and framing nailers at all
Makita do make Framing Nailers
Sorry I meant to say cordless. I know they make pneumatic nailers I want to look into a few of them
jswoger1986 wrote:
9 hours ago, jswoger1986 said:Sorry I meant to say cordless. I know they make pneumatic nailers I want to look into a few of them
They do make cordless (with gas) ones. http://www.makita.co.nz/products/model/GN900SE
I wish they would make an 18v one like Dewalt do, if thats what you meant.
On 6/22/2016 at 7:12 PM, JimboS1ice said:ryobi sells a cordless inflator tool for about 20 bucks. I don’t think the blower could generate enough pressure for that type of inflation, its not an actual air pump
Are you referring to this inflator? This one has two modes one (the side depicting a tire) is for high pressure lower volume things i.e. tires or basketballs, the other side (depicting an air mattress) is for lower pressure higher volume devices i.e. beach balls and air mattresses. It does cost $40 though although I would consider it worth it.
I also agree with the inflator. That is universal with all brands I believe since Ryobi is still the only one I believe.
At this point there’s not a lot out there missing between brands. Maybe the cordless box fan for Dewalt.
I’ll second on the inflator ….. But I would really like to see a “yellow” 20v pvc cutter.. It just seems like I do a lot of irrigation work around the house
On 6/25/2016 at 2:47 PM, JimboS1ice said:
Ah I see, I skipped that one since I already had the one I linked which is this one, but can do more, is bigger and more expensive.
I’m impatiently waiting for a Brushless multi tool from Milwaukee
Me too! So impatient I think I’m gonna buy the brushed version anyways! I have a few extra batteries from the recent promos I need something to put it on lol
The M18 brushed multi-tool works fine for me. Only thing I really use them for is for cutting-in boxes, anyway. Did hold off on buying it for a while, expecting a brushless release. Most everything I have is brushless, but not sure that I’d really need the benefit of one.
Inflator is something I wish Milwaukee made. So many uses for those (yes TTI, even for “professional users”).
Multitool is something I wish Milwaukee made *well*. 3 years old, brushed, and with a tool-less but not flawless blade change is part of why I ordered the Dewalt today.
Something I’m glad they excel at is making Sawzalls. The Fuel is a joy and using other cordless recips has been a pain. The new Makitas and FlexVolt look to remedy that though.
I’ll also mention that I’m happy they blazed a trail with brushless high torque impacts. My 2763 is a joy to use.
After struggling with rivets on my radius arm brackets, in where I couldn’t get my M18 angle grinder, and where I didn’t have air available, it would be nice if Milwaukee offered an M18 Fuel 1/4″ die grinder, comparable to a Milw. or Makita electric one. Between a bur in the M12 rotary and a hammer and chisel, not a lot of fun.
I”m committed Dewalt and Milwaukee at the moment. Looking into other options for mitre saws…
sparky603 wrote:
2 hours ago, sparky603 said:After struggling with rivets on my radius arm brackets, in where I couldn’t get my M18 angle grinder, and where I didn’t have air available, it would be nice if Milwaukee offered an M18 Fuel 1/4″ die grinder, comparable to a Milw. or Makita electric one. Between a bur in the M12 rotary and a hammer and chisel, not a lot of fun.
They have one naina.
jeffmcmillan wrote:
7 minutes ago, jeffmcmillan said:They have one naina.
Thanks for the reply! I’ll check it out.
