Hey gang,
Well, I’ve gone and done it. I ordered a new Makita LS1016L SCMS! It will be my first miter saw, and I’d like to outfit it with a decent blade.
From what I understand, I should probably be looking for a 10″ with 60-80 teeth. I also am aware that with a slider, a small positive tooth angle, or even negative angle, is preferred. I a few Diablo makes one for a SCMS, D1060S. I believe it has a 7 degree positive angle.
Thoughts?
Diablo makes great circular saw blades, would probably get the 80 tooth then something lower for more rough cuts
Another vote for Diablo blades here. Ive heard good things about Forrest blades too.
Thanks guys. I ended up buying a aFreud LU74R010 10-inch 80-tooth. I read some positive reviews, but haven’t tried it yet. The blade that came with the saw actually seems like a quality one, with 60 teeth.
That’s a nice blade too. I have several Freud blades. Great carbide on them can be sharpened several times.
I like the Diablo blades.
Freud and diablo are one and the same.
That’s way too many teeth IMO unless you’re building cabinet grade projects. I run 44T Diablo’s in my 12″, if tear out is a concern when running door casing or the like, I just put a piece of sacrificial material against the fence…flawless cuts for less than half the cost.
Hugh Jass wrote:
3 hours ago, Hugh Jass said:That’s way too many teeth IMO unless you’re building cabinet grade projects…
I’ll remember that next go-around. Thanks for the tip.
zero clearance insert helps that a lot too….have one on my 12″ milwaukee cuts like a dream
