Who makes the Best Tile Blade
I was talking to a buddy today and he is doing a flooring job.  He ask me what the best tile saw blade was and I was at a lose.  He has a Ridgid 8″ wet tile saw and he said he was going through a blade a day and couldn’t find a good one.  So I figure I would tap you guys and see who has some experience and what they recommend.  Thanks
Wish I could help… Bosch makes some great diamond rim blades for grinders not sure if they have an 8″
Seems like he’s gotta be using the wrong blade? How long has he been running his current saw setup? MK is another brand I’ve heard good on
I have a QEP 10″ and a MK 7″. I have had good luck with the QEP porcelain blades and the MK blades as well. A blade a day does not seem right?
MK makes some good blades.  Running through one a day is crazy with any blade.  Might be a problem with the saw.
phffterMember since Mar 2016
hf are junk.
bought a couple of bosch for the next project
phffter wrote:
2 hours ago, phffter said:
hf are junk.
i avoid anything with a cutting edge, id feel safer playing golf in a lightning storm than anything of their involving a grinder
bosch metioned was for a wet saw.
cutting edge – i use metabo grinders  with cut off wheels frequently
no need to be afraid of them. only with proper ppe
phffter wrote:
I was just talking about HF grinder disc
DaveJr.Member since Nov 2015
I have an MK 10″ saw and the blade was used to do a kitchen floor, backsplash and an entire bathroom, floor and walls,  and the blade still looks brand new.
Rubi makes the best diamond blades for flooring. Wet, dry, 4″ – 10″. Specialty blades for any material.
