I might have to look into some dust collection
Cmon! Seriously? What’s wrong with emphysema? Serious, dust scares me. Not much else but dust scares the crap out of me. What are you using for the chairs, is it cedar?
Probably a good idea !!!!
good luck with the chairs for St. Jude
looks to be cedar, however it is so dusty it could be walnut….lol
DaveJr.Member since Nov 2015
I use a “Dust Deputy” made by Onieda Air Systems. It goes on top of any container and hooks right up to a shop vac. Not sure if you know about dust collectors or not but it is a cyclone type collector. It goes between the tool and the shop vac. 99% of the dust with go into the container so you don’t have to clean the filter out as often. If you don’t want to break the bank, you can’t go wrong with it. $56 shipped for the cyclone and the only other things you will need are 6 nuts and bolts and a rubber gasket or some caulking to seal between the separator and the container. I use a 5 gallon bucket but find that it gets filled pretty quickly. One of those blue plastic 55 gallon drums with a removable lid would work out great. For the container though, you need something that is very sturdy or else the vacuum will crush it. Hope this helps.
http://www.amazon.com/Oneida-Molded-Dust-Deputy-Cyclone/dp/B002JP315K?ie=UTF8&keywords=dust%20deputy&qid=1462229455&ref_=sr_1_1&sr=8-1
yes dust deputy was probably best thing I bought for my shop.
dwainMember since Aug 2013
most useful thing I’ve made for my shop too…
rrich1Member since Jun 2015
Yes it is ceder. Got the bottom slats on one of the chairs before I had to come to work tonight.
Thanks for the link. Ill look into it. I think with the amount I would be doing a 5 gal bucket would work.
