Milwaukee Impact Driver (2656-20) Loose Battery Wobble
This is New today… My drill no others do this.  The 18v batters has a little play front to back, but what is bothering me is the play side to side I can move it side to side about 1/8″…. Anyone else have this issue? Normal?
Note: added short video in post below.
Here is a quick video I just made while working on my lawn mower.Youneed to turn the sound up so u can hear it.  Got this tonight. Worried it will be super loose in a year?  Should I exchange it tomorrow?
Video: https://youtu.be/nuVEZ2BgfPQ
Sorry, can’t really see a problem, that seems normal to me. What are you comparing it to that it seems loose? Any cordless power tool i’ve used can do that, Makita, Ryobi, Dewalt, Milwaukee, maybe there is one or two out there that has extremely close tight fit, but I never give it a thought unless it’s extremely bad
I recall Dan complaining about this but I think it was on a Dewalt.
Yes my dewalts have slightly more play than the Milwauke but they both jiggle a smidge, nothing to be alarmed about its normal for slide packs
Ok thanks guys. My drill has none. Solid
Tim C wrote:
Ok, good! Could you do another video showing both impact and drill and how tight each battery is? Then we can get a comparison for each tool and i will check mine, as well…
Maybe you can put some electrical tape on the inside of the tool to tighten that up if it bothers you.
khariVMember since Dec 2014
Is the wobble intentional to keep all of the vibrations from transferring into the battery pack? I’ll have to check all of my M18s to see how tight they are.
khariV wrote:
 I don’t think that’s the case.  High vibration tools like an OMT (seriously the name includes a synonym for vibrating) or hammer drill typically have rubber bumpers to dampen vibration to the battery while keeping it snug.
All three of my m18 impacts have a bit of wobble. None have came loose or lost connection though. I imagine they don’t want them to have a right fit due to the vibrations getting to the battery.
Here is another video. Really have to show on video. Drill first and driver 2nd. It’s the same with both batteries on the driver. It’s only 2 days old. Get dif one or keep?
Video Link:
I just tested all my M18s, only my sawzall has that much play. I never noticed it. You could try returning it for a new one but I wouldn’t worry about it. Both my drills, both impacts and jigsaw have the same amount of play as your drill.
I don’t think you got nothing to worry about either but to ease your mind take it back and try another kit, some of my Dewalts have some play but over never had any problems while using them.
Bmill25Member since Jul 2015
Is it possible that it’s the battery that’s the issue and not the tool?
MikeInCtownMember since Mar 2016
My new one key impact driver has the side to side play as did the new fuel impact driver that I returned. The drills do not have the side to side play. It gets annoying because the battery does shake a little as the tool is impacting and you get more feedback than you should.
Hey Tim I know u just picked this kit up but did you see the milwaukee bundle deal that HD is running today? It’s a really nice price for more tools bro I would definitely check it out.
Bmill25 wrote:
No i dont think so, both batteries do it in the driver.  I am gonna go to home depot tomorrow to pick up some things.  I will check out the displays and see if they do it.
Hey I just saw this post, I paid $169 for my kit.  Looks like its now $200 for my kit in store and if you order online its $200 and comes with light.  Do not see the cheaper on.
im sorry Tim I should’ve posted a link but I was in a rush here at work, I think it was a one day sale promo ill try and find and if I do ill post here oh as a matter of fact it was posted on daily deal thread under HD deals.
yes seems to be a hit or a miss, mass produced, is most likely within tolerances but for personal reasons I can see it being a bother. none of my M18 line do it or enough to notice….if it is not to much trouble go to store and check a few sets out and pick the one you are most comfortable with. I will tell you however, none of mine have changed over time which would be the main reason I would concerned.
khariV wrote:
This appears to be the case, the battery is not meant to be completely snug on the tool, because I read that the electrical connections are able to move around and take the vibration of the tool, instead of trying to keep the battery completely snug on the tool, which is impossible with high vibrations some tools experience….
Mystery solved, and also, there is a gen 2 high torque impact wrench coming!!!
Notice the vibration on the battery, but the connections in the tool are springy and move with the battery so they can take the vibration. The battery moving around on the tool is accounted for…
  • jkirk_trimkat Lots of power. Only thing I noticed that could be a concern is the battery bouncing around.. the contacts could get bad over time
  • krugerconstruction@jkirk_trimkat man so funny you say that! When I was at the service center they showed me the inside of batteries and also pointed out the battery connector on the bottom of the tools. Most of them are spring loaded so the connections move with the battery rather then the tool. Also the connection to the cells have 4 separate welds rather then 1 like on other manufacturers. I was impressed to see the inside of there packs in person ? Dirck sorry for bombing on your post I don’t enjoy people doing it to me all the time, I was actually going to do a post about this
  • jkirk_trimkatAhh so they’ve already addressed it with shock absorbtion per say similar to makita with their 18v bx impact wrench
  • krugerconstructionExcept they pointed out one of the tools that doesn’t have it is the high torque impact wrench lol the 2nd gen will have it though ?@jkirk_trimkat
  • ack_workbench@krugerconstruction No worries. Good information. I was surprised to see all that movement!
@Tim C I would also take your phone number down if I were you, never know….
I meant to ask you why you were concerned with this original query? Do you have other platforms to compare with or is this your first cordless and were questioning out of a general concern? I actually took that one instagram post i put here a step further and took my 2712 SDS+ drill and the terminals are indeed spring loaded to always put pressure on the battery.
Wow man, thanks for all the really great info and posts!  My new fuel set I got about a month ago now has wobble. It was my first Milwaukee set and I was just worried. My previous Dewalt was like a rock. I am comfortable with my batteries  being a little loose now.
M18 contactsMember since Jul 2019
Hi . My batteries in my M18 impact started moving a while ago and now the contacts are burnt and the  shorter outer connectors on the gun don’t reach the battery ..   and I have to push battery onto contacts to make it work and been told that various other parts have to be changed as it’s been updated …out of warranty so sounds expensive…anyone else had this happen and does anyone know of a fix for it
LocksmithMember since Oct 2019
Bought m18 twin set today battery slight wobble didn’t like it so cured with a bit of draught excuse on the inside rim and edge where the battery connects to the drill mo more wobble perfect fit and still has dampening so vibration is not transferred directly to the battery when operating
ZackMember since Jan 2021
I am facing this issue too. Just received a 1/2 mid torque and the battery definitely has some play/movement. Is this normal? Seems like a lot of people experience this.
