Archived from the Tools In Action forum (Introduce yourself). This thread is read-only.
Hello,.. Allentown , I wanted to comment on Ryobi jigsaw blades ..bosch will not fit and home depot offers as extra blades .Do not buy also don’t have Ryobi blades
ok,welcome to the forums I’m sure there are other alternatives to jigsaw blades…
I use Bosch blades in my Ryobi jigsaw…
Kato wrote:
41 minutes ago, Kato said:I use Bosch blades in my Ryobi jigsaw…
Kato, bosch jigsaw blades are about the best on the market, there are some diablos around, but not easily available, never seen any in store, i use exclusively the bosch!
So how do the bosch not fit? I had a ryobi that i used bosch t-shank blades in, make sure you have the proper style, if you have the u-style they won’t fit, pretty sure ryobis take the t shank design, but double check with the manual.
Bosch fit my 18v jigsaw just fine. Maybe the OP has a different saw and the Bosch don’t work, or maybe it’s a matter of not installing them properly. More info would be helpful…
Yes you have to make sure you pull the spring enough and give it a little push into where the blade goes, but again you need to have the right style of blades, HD sells both styles
Welcome to the forum Rose. To echo Jimbos suggestion check the blade types that you bought. The attached picture should help you out. I use Festool and Bosch blades. They are really nice blades from each maker and have some great qualities especially for endurance.
Hope this helps and let us know how you made out!
[Photo from the original forum is not in the backup]
Yup, sometimes on the Ryobi it’s hard to get the lock open all the way, that dumb guard gets in the way
These guys might have a solution for your problem. Didn’t know if you had seen the post from the guys. Or if you knew that anyone had replyed.
Millerz
Welcome to the forum rose! What they said::)
Welcome to the crew Rose!!
