New Sharkbites
A new innovation from Sharkbite, PVC fittings (schedule 40 PVC) . If you can’t glue PVC pipe together than you shouldn’t be doing plumbing work. I don’t see a need for this, they make pvc glue that you can use underwater. Why would you need this? Any thoughts on this?? Second picture is a 1 inch PVC to 1 inch copper coupling
there are a lot of people that shouldn’t do any plumbing and they still do…..so if they can sell it by all means…..
Because people’s laziness makes them money
Is it double post Friday?
Haha, it said error or something like that and than bam!! I didn’t realize till you said something, You would think being lazy you would also be a penny pincher
As long as it doesn’t leak and $h!t goes down hill your good to go right..lol
Huh, well, we use their CTS compatible fittings from time to time, but only joining between dissimilar pipe material, I don’t exactly know what to think of them, but they’re not the first thing I would reach for. I never used their PVC compatible fittings, don’t intend to…..
I like using them in tight and hard to get to places. And only on remodels do I use them. And they’re really expensive too. So I don’t use them much. I bet that one in the pick is near 10 dollars ain’t it? Fast and easy I guess.
Millerz
I hear they are popular. All the iodine, chlorine, acid, detergent, formaldehyde, and compressed air plumbing I do, I use something that is similar to sharkbites on 3/8 tubing. Never had a premature failure. [External image (uploads.tapatalk-cdn.com), not copied] I was super skeptical of the sharkbites when I first saw them and would never install them in my home.
If these fittings were Around when I worked in my old bosses shop there was no way in the world he would have let us use them. We were barley allowed to use speedy flexes, you had to use tubes and bend them by hand. The way he put it was we are Plumbers not Handymen! And we only used  pvc for DWV only when absolutely necessary, no-hub was the preferred choice. And we were one of the only shops in the neighborhood that was still pouring lead/oakum joints. For me it was a great way to learn the hard way rather then an easier way.
Now we use no hub only when absolutely necessary, and pvc the preferred choice
Yup, I’m the same way only use them when the shut off at the street won’t hold. I see a few guys use them to transition from copper to cpvc which is done very often here. The Sharkbite is the same price vs a copper female adapter and a stainless cpvc male adapter plus no sweating, dope, Teflon and screwing around..lol But like I said I only use them when the water won’t shut off all the way.
MikeyB wrote:
Old school plumbers know what works and what doesn’t work, they probably looked at these sharkbites and just shaked there head.
Pvc is the way to go
Sharkbite is for a quick TEMPORARY repair as far as I am concerned. THAT’S IT. I would NEVER put them inside a wall. They’re sealed by an o-ring. Why would anyone ever put them in as a permanent joint, is beyond me.
RickyMcGrath wrote:
I agree, I do have some out there that have become permanent because they never called back to fix it right. I guess they just don’t want to pay any more money. I use them when the shut off at the street leaks by, you tell the owner he needs to have the city come out and change the shut off. But the owner doesn’t care. I have some inside slabs and you tell them its just a temp until house gets repiped, but the house never gets repiped and they just cement back over it. I wish some people will just listen
MikeInCtownMember since Mar 2016
These things are great for transitioning between material and in homes where you have pipe running tight along basement joists or walls. You can’t solder without risk of fire, and if you have water running out of the pipe, these are perfect. Would I build new construction with them? Nope, but I sure would use them for repair in accessible areas where use of a torch is not preferable.
MikeInCtown wrote:
I usually squeeze a fire blanket or a piece of sheet metal behind any pipe touching wood. then solder my fitting.
Propress baby!
3 hours ago, KnarlyCarl said:
Propress baby!
Sweet!!! And a sharkbite too.lol I’ve been having problems with those Delta valves, the cartridge goes bad quick. I get lucky some times and just change the seats and springs. I had a call back on one a week after my warranty expired sucks to be them..lol
Propress baby!
Pro-press, sharkbite AND a Uponor ProPEX.
Yes, it was a massive pain in my rear replacing that shower valve, Icouldn’t access out from the rear side
Were you able to do it without any tile repair?
Yes, just barely. Wouldn’t have been able to if I had to solder everything old school style
Yea changing shower valves is the worst, I price them high with no guarantee that tile can be saved. Around here a lot of them are on outside walls where this is only an inch from the durock to the cinder blocks. We have just a 1/2” furring strip attached directly to the cinder block walls and then the drywall directly on the furring strip. I would rather do a slab leak repair then a shower valve any day
Yes it’s good seeing pro plumbers using what use to be strictly a consumer product. Have saved my sanity several times. Thanks guys.
PROTOOLNUT wrote:
31 minutes ago, PROTOOLNUT said:
A shark bit me, shit, should have used the other fitting. 😛 I think its funny watching you guys talk plumbing for hours hehe
You have no idea, last Saturday on Google hangouts we talked about HVAC for almost 7 hours live.lol There was a hangout last night that lasted 2 hours, and there will be another one tonight 🙂
